Current turning capabilities status
16 Feb 2013 04:09 #30150
That might need to be sudo dmesg --clear
Replied by andypugh on topic Current turning capabilities status
dmesg --clear
16 Feb 2013 04:12 #30151
Replied by PCW on topic Current turning capabilities status
Thats right, will fix
16 Feb 2013 04:32 #30153
by BigJohnT
Replied by BigJohnT on topic Current turning capabilities status
Or
sudo dmesg -c
sudo dmesg -c
16 Feb 2013 06:13 #30157
by emcPT
Replied by emcPT on topic Current turning capabilities status
Will post that earlier in the morning, as soon I get to work.
16 Feb 2013 15:56 - 16 Feb 2013 16:03 #30183
by emcPT
So I attached the requested files.
I must say that I installed a fresh ubuntu, then only updated all the available packages, but not the ubuntu itself as it is recommended.
Last edit: 16 Feb 2013 16:03 by emcPT. Reason: added oncconfig
16 Feb 2013 16:22 - 16 Feb 2013 16:26 #30184
by emcPT
I can not imagine why, but I was unable to upload the pncconfig file.
Last edit: 16 Feb 2013 16:26 by emcPT.
16 Feb 2013 20:02 #30186
The problem is
"okuma.hal:107: parameter or pin 'bldc.2.drive-offset' not found"
But I have no idea at all why pncconf has inserted a bldc function in your HAL file.
Can you post the HAL file?
16 Feb 2013 21:36 #30188
Is it the same problem as here?
www.linuxcnc.org/index.php/english/forum...ation?start=18#30187
Deselect "brushless motor control" in PncConf.
The following user(s) said Thank You: emcPT
16 Feb 2013 22:17 #30190
by emcPT
If my motors are brushless, I could make the pncconfig x10 times more changing things that I would never changed that.
It did the trick, but I keep on wondering how many of those subtil issues I will encounter.
But ok! it is done, and I get the front end.
I will now read a bit and try to configure a spindle outputs and encoder feedback as my VFD will be here next week.
17 Feb 2013 04:07 #30202
The brushless motor option is only for very specific configurations where LinuxCNC does the commutation. (pncconf should probably indicate this)
There is no difference in the configuration needed if standard analog brushed or brushed servos with interfaces are used
Moderators: piasdom
Time to create page: 0.160 seconds
