7i80 and 7i77
28 Oct 2014 04:34 - 28 Oct 2014 04:59 #52461
by uli12us
Replied by uli12us on topic 7i80 and 7i77
The newest version was already installed, but I get no reaction.
At the start of LCC I get a list with pins, but only a part of the existing.
It ends with P3-17 or Pin50 (P3--
And in the last line hm2/hm2 7i76e.0: registered
If I send ping, the 4 user leds count digitally up, so I think the communication is ok.
My fault, I get a list, but only after LCC is quitted.
I think thats the proof, that I have communication.
Last edit: 28 Oct 2014 04:59 by uli12us.
28 Oct 2014 05:23 #52464
Replied by PCW on topic 7i80 and 7i77
can you post what linuxcnc prints at startup?
28 Oct 2014 05:36 #52465
by uli12us
LINUXCNC - 2.8.0~pre0
Machine configuration directory is '/home/uli/linuxcnc/configs/7i76e'
Machine configuration file is '7i76es1.ini'
Starting LinuxCNC...
Note: Using POSIX realtime
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: WARNING: Unable to restrict other access to the hm2-eth device.
This means that other software using the same network interface can violate
realtime guarantees. See hm2_eth(9) for more information.
hm2_eth: Hardware address: 00:60:1b:10:40:0c
hm2_eth: discovered 7I76E-16
hm2/hm2_7i76e.0: 51 I/O Pins used:
hm2/hm2_7i76e.0: IO Pin 000 (P1-01): StepGen #0, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 001 (P1-14): StepGen #0, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 002 (P1-02): StepGen #1, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 003 (P1-15): StepGen #1, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 004 (P1-03): StepGen #2, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 005 (P1-16): StepGen #2, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 006 (P1-04): IOPort
hm2/hm2_7i76e.0: IO Pin 007 (P1-17): IOPort
hm2/hm2_7i76e.0: IO Pin 008 (P1-05): IOPort
hm2/hm2_7i76e.0: IO Pin 009 (P1-06): IOPort
hm2/hm2_7i76e.0: IO Pin 010 (P1-07): IOPort
hm2/hm2_7i76e.0: IO Pin 011 (P1-08): IOPort
hm2/hm2_7i76e.0: IO Pin 012 (P1-09): IOPort
hm2/hm2_7i76e.0: IO Pin 013 (P1-10): IOPort
hm2/hm2_7i76e.0: IO Pin 014 (P1-11): Encoder #0, pin Index (Input)
hm2/hm2_7i76e.0: IO Pin 015 (P1-12): Encoder #0, pin B (Input)
hm2/hm2_7i76e.0: IO Pin 016 (P1-13): Encoder #0, pin A (Input)
hm2/hm2_7i76e.0: IO Pin 017 (P2-01): IOPort
hm2/hm2_7i76e.0: IO Pin 018 (P2-14): IOPort
hm2/hm2_7i76e.0: IO Pin 019 (P2-02): IOPort
hm2/hm2_7i76e.0: IO Pin 020 (P2-15): IOPort
hm2/hm2_7i76e.0: IO Pin 021 (P2-03): IOPort
hm2/hm2_7i76e.0: IO Pin 022 (P2-16): IOPort
hm2/hm2_7i76e.0: IO Pin 023 (P2-04): IOPort
hm2/hm2_7i76e.0: IO Pin 024 (P2-17): IOPort
hm2/hm2_7i76e.0: IO Pin 025 (P2-05): IOPort
hm2/hm2_7i76e.0: IO Pin 026 (P2-06): IOPort
hm2/hm2_7i76e.0: IO Pin 027 (P2-07): IOPort
hm2/hm2_7i76e.0: IO Pin 028 (P2-08): IOPort
hm2/hm2_7i76e.0: IO Pin 029 (P2-09): IOPort
hm2/hm2_7i76e.0: IO Pin 030 (P2-10): IOPort
hm2/hm2_7i76e.0: IO Pin 031 (P2-11): IOPort
hm2/hm2_7i76e.0: IO Pin 032 (P2-12): IOPort
hm2/hm2_7i76e.0: IO Pin 033 (P2-13): IOPort
hm2/hm2_7i76e.0: IO Pin 034 (P3-01): IOPort
hm2/hm2_7i76e.0: IO Pin 035 (P3-14): IOPort
hm2/hm2_7i76e.0: IO Pin 036 (P3-02): IOPort
hm2/hm2_7i76e.0: IO Pin 037 (P3-15): IOPort
hm2/hm2_7i76e.0: IO Pin 038 (P3-03): IOPort
hm2/hm2_7i76e.0: IO Pin 039 (P3-16): IOPort
hm2/hm2_7i76e.0: IO Pin 040 (P3-04): IOPort
hm2/hm2_7i76e.0: IO Pin 041 (P3-17): IOPort
hm2/hm2_7i76e.0: IO Pin 042 (P3-05): IOPort
hm2/hm2_7i76e.0: IO Pin 043 (P3-06): IOPort
hm2/hm2_7i76e.0: IO Pin 044 (P3-07): IOPort
hm2/hm2_7i76e.0: IO Pin 045 (P3-08): IOPort
hm2/hm2_7i76e.0: IO Pin 046 (P3-09): IOPort
hm2/hm2_7i76e.0: IO Pin 047 (P3-10): IOPort
hm2/hm2_7i76e.0: IO Pin 048 (P3-11): IOPort
hm2/hm2_7i76e.0: IO Pin 049 (P3-12): IOPort
hm2/hm2_7i76e.0: IO Pin 050 (P3-13): IOPort
hm2/hm2_7i76e.0: registered
BoardName : MESA7I76
FPGA Size: 16 KGates
FPGA Pins: 256
Number of IO Ports: 3
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: StepGen
There are 5 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: QCount
There are 1 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5A00
Instance Stride: 64 bytes
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for on-card
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort StepGen 0 Dir/Table2 (Out)
14 1 IOPort StepGen 0 Step/Table1 (Out)
2 2 IOPort StepGen 1 Dir/Table2 (Out)
15 3 IOPort StepGen 1 Step/Table1 (Out)
3 4 IOPort StepGen 2 Dir/Table2 (Out)
16 5 IOPort StepGen 2 Step/Table1 (Out)
4 6 IOPort StepGen 3 Dir/Table2 (Out)
17 7 IOPort StepGen 3 Step/Table1 (Out)
5 8 IOPort StepGen 4 Dir/Table2 (Out)
6 9 IOPort StepGen 4 Step/Table1 (Out)
7 10 IOPort SSerial 0 TXData1 (Out)
8 11 IOPort SSerial 0 RXData1 (In)
9 12 IOPort SSerial 0 TXData2 (Out)
10 13 IOPort SSerial 0 RXData2 (In)
11 14 IOPort QCount 0 Quad-IDX (In)
12 15 IOPort QCount 0 Quad-B (In)
13 16 IOPort QCount 0 Quad-A (In)
IO Connections for P1
1 17 IOPort None 0 None (In)
14 18 IOPort None 0 None (In)
2 19 IOPort None 0 None (In)
15 20 IOPort None 0 None (In)
3 21 IOPort None 0 None (In)
16 22 IOPort None 0 None (In)
4 23 IOPort None 0 None (In)
17 24 IOPort None 0 None (In)
5 25 IOPort None 0 None (In)
6 26 IOPort None 0 None (In)
7 27 IOPort None 0 None (In)
8 28 IOPort None 0 None (In)
9 29 IOPort None 0 None (In)
10 30 IOPort None 0 None (In)
11 31 IOPort None 0 None (In)
12 32 IOPort None 0 None (In)
13 33 IOPort None 0 None (In)
IO Connections for P2
1 34 IOPort None 0 None (In)
14 35 IOPort None 0 None (In)
2 36 IOPort None 0 None (In)
15 37 IOPort None 0 None (In)
3 38 IOPort None 0 None (In)
16 39 IOPort None 0 None (In)
4 40 IOPort None 0 None (In)
17 41 IOPort None 0 None (In)
5 42 IOPort None 0 None (In)
6 43 IOPort None 0 None (In)
7 44 IOPort None 0 None (In)
8 45 IOPort None 0 None (In)
9 46 IOPort None 0 None (In)
10 47 IOPort None 0 None (In)
11 48 IOPort None 0 None (In)
12 49 IOPort None 0 None (In)
13 50 IOPort None 0 None (In)
28 Oct 2014 05:47 #52466
That's all correct but it indicates the the field I/O is not working
so do you have
1. Field power (>8VDC, <32VDC) on TB1
2. W1 left CR8 on
so do you have
2. W1 left CR8 on
28 Oct 2014 06:23 #52468
by uli12us
The screw on TB1 was loose and I don't know if W1 is on. I couldn't find in which position is on or off.
Its in the left hand position.
28 Oct 2014 07:02 - 28 Oct 2014 07:02 #52470
So after connecting the field power properly, verifying that W1 is in the left hand position (7I76E manual
pages 2 and 13), and verifying that you have a valid field power source (>8VDC and <32 VDC)
and that CR8 is on, do you have remote I/O pins available in you HAL file after starting linuxcnc
(halcmd show pins)
(halcmd show pins)
Last edit: 28 Oct 2014 07:02 by PCW.
29 Oct 2014 03:46 - 29 Oct 2014 05:37 #52512
by uli12us
I get a long list of pins, but don't know a possibility to save them. Nearly none of the many descriptions say me anything.
I haven't found anything with remote in the name.
The principle function seems ok, because I have used a LED to see if I have tension on the clamps. If I use an axe key the corresponding led lights up. But I get often a joint 0 or 1 error. Don't know what this is.
I have changed the parameter from up/down to step dir, then it works, but if I disable velocity mode, I get the joint Error in the same moment as I touch the axe key. I have tried to run the demoprogram, but get immediately the same error.
Last edit: 29 Oct 2014 05:37 by uli12us.
29 Oct 2014 07:20 - 29 Oct 2014 08:16 #52514
Remember when I said you would need to widen the ferror limits if you dont have the DPLL?
The ferror limits in those example files (that assume a DPLL) are quite small
wiki.linuxcnc.org/cgi-bin/wiki.pl?Following_Error
Last edit: 29 Oct 2014 08:16 by PCW.
29 Oct 2014 21:23 #52530
by uli12us
I've tried to change Ferror without success, than I tried to reduce the speed, that works, but the speed is reeeealy slow.
After that I changenged the speed from setup to the working speed, but that don't works. I get half a dozen errors, beginning always with low voltage, although my field power is 24V with 2Amps.
29 Oct 2014 21:37 #52531
Did you make both ferror and min_ferror larger on all axis?
Is your 24V supply _filtered_ DC?
You are not likely to get low voltage complaints unless your field power supply has issues
Time to create page: 0.262 seconds
