Hardware & Machines
Driver Boards
7i80 and 7i77
7i80 and 7i77
Thank you received: 5263
15 Mar 2017 11:18 #89656
Sserial "DoIt not cleared" messages are most commonly caused by real time delays
(the cycle after a late cycle doesn't have enough time to complete)
The "tmax" values are parameters rather than pins
Another useful parameter is "servo-thread.tmax" which is the entire servo thread maximum time, and
the pin "motion.servo.last-period" which is the entire period
If you have a 3 GHz CPU, divide the timing numbers by 3000 for uSecs
The following user(s) said Thank You: jCandlish
Hardware & Machines
Driver Boards
7i80 and 7i77
