Why Mesa 5i20 does not start?
01 Aug 2016 01:34 #78214
by pkasy
Why Mesa 5i20 does not start? was created by pkasy
I never could find the answer to my question, maybe I do not ask it correctly.
When the computer starts, the paddle LEDs are lit on the board.
But when I try to run linuxcnc or pncconf with any firmware Mesa board immediately extinguishes the LEDs and does not work.
tell me why? what it lacks?
01 Aug 2016 01:52 #78215
Replied by PCW on topic Why Mesa 5i20 does not start?
The LEDs going off is a good thing
(it means the card was successfully programmed by the host PC)
What makes you think the card does not work?
01 Aug 2016 02:22 #78216
by pkasy
Replied by pkasy on topic Why Mesa 5i20 does not start?
thank you.
Because 5i20 did not issue the outputs.
I have the same card, it is on the milling machine. On it LEDs are lit continuously.
01 Aug 2016 03:38 #78220
Do you get any error messages?
I would not expect any LEDs on unless the hal file turns them on
01 Aug 2016 11:19 #78228
by pkasy
no, I didn't get any error messages in the terminal or dmesg.
I checked the 8 green LEDs, and found I can turn on them all.
but both 7i33 and 7i37 do not act.
I can’t make enable, pid output and so on at 7i33 and can’t drive 8 output keys.
01 Aug 2016 13:31 #78234
That does sound a bit more like a HAL setup error that something wrong with the 5I20
01 Aug 2016 23:03 - 01 Aug 2016 23:25 #78261
by pkasy
This is fresh install right after pncconf.
LinuxCNC 2.7.5
loadrt hm2_pci config="firmware=hm2/5i20/SVST8_4.BIT num_encoders=4 num_pwmgens=3 num_stepgens=0"
7i37
# --- SPINDLE-CW ---
setp hm2_5i20.0.gpio.064.is_output true
net spindle-cw hm2_5i20.0.gpio.064.out
LinuxCNC 2.7.5
7i37
Last edit: 01 Aug 2016 23:25 by pkasy.
01 Aug 2016 23:13 #78262
Still sounds like a configuration issue of some kind
if the red lights go out and you dont have a startup error, the card did "start"
What linuxcnc version are you using?
Can you post your hal and INI files here?
02 Aug 2016 00:06 #78266
by pkasy
pins 65 and 67 always ON on the board 7i37
pins 64, 66, 68, 69, 70, 71 always OFF.
if I disconnect the cable from the board 7i37, all signals are switched off.
It is something inside 5i20.
02 Aug 2016 00:22 - 02 Aug 2016 00:22 #78267
Are they on before the card is configured (linuxCNC running) ?
If so that suggests a bad (damaged) FPGA or possibly bad cable
Last edit: 02 Aug 2016 00:22 by PCW.
Time to create page: 0.097 seconds
