My 7i76e Connection Sheet
05 Oct 2022 04:39 #253496
Replied by rodw on topic My 7i76e Connection Sheet
Whats wrong with connecting to TB3? Its there for this purpose. I use it.
20 Feb 2023 00:08 #264840
by fons
Replied by fons on topic My 7i76e Connection Sheet
a year ago i work on a mile machine and that time it work it move i work with mesa 7i76e.
i have 2 setups a big one in the workshop (way to cold now) and a smale one (coosie warm) to experimenting in house
it stay there unused no time and now i pick it up again
the one in the workshop stil work
when i take the laptop in house i got an error when i take the laptop again to the workshop with the same config work
what can be the reason
i got these error message the last lines
hm2/hm2_7i76e.0: registered
hm2_eth: hostmot2 ethernet driver unloaded
hm2: unloading
removing hal_lib, rtapi, and real time os modules
removing nml shared memory segment
debug file information
note: using posix realtime
./sin20220818.hal: pin 'hm2_7i76e.0.7i76.0.0.output-00' does not exist 1552
stopping realtime threads
unloading hal components
someone had an idea how i can solve thise problem ?
hm2: unloading
20 Feb 2023 00:17 #264842
Replied by PCW on topic My 7i76e Connection Sheet
Typically, that error means that the 7I76E does not have field power
The following user(s) said Thank You: fons
20 Feb 2023 00:31 #264843
by fons
for noise reason i didn't switch it on and that was critical thx it work now
- Amin Laakel Sofet
23 Jan 2024 14:18 - 23 Jan 2024 14:28 #291424
by Amin Laakel Sofet
Replied by Amin Laakel Sofet on topic My 7i76e Connection Sheet
Hi, I'm having a similar error code when trying to run LinuxCNC
Note: Using POSIX realtime
".custom.hal:81: Pin 'hm2_7i76e.0.7i76.0.0.enc0.count' does not exist"
3999
(The 3999 number changes everytime we try to start up the program)
This only happens when we use a specific code in our custom.hal to control the axis' with a MPG controller.
We've already checked the field power TB1 (pin 5 +24V pin 8 GND) and when we measure P3 there is a 5V available.
The Custom.Hal we used is below.
loadrt mux4 count=1
loadrt mux8 count=1
loadrt select8 count=1
loadrt conv_float_s32 count=1
addf mux4.0 servo-thread
addf mux8.0 servo-thread
addf select8.0 servo-thread
addf conv-float-s32.0 servo-thread
# For velocity mode, set to 1
# In velocity mode the axis stops when the dial is stopped
# even if that means the commanded motion is not completed,
# For position mode (the default), set to 0
# In position mode the axis will move exactly jog-scale
# units for each count, regardless of how long that might take,
setp axis.x.jog-vel-mode 0
setp axis.y.jog-vel-mode 0
setp axis.z.jog-vel-mode 0
# This sets the scale that will be used based on the input to the mux4
setp mux4.0.in1 0.001
setp mux4.0.in2 0.01
setp mux4.0.in3 0.1
# This selects axis (off=0, x=1, y=2, ...)
setp mux8.0.in0 0
setp mux8.0.in1 1
setp mux8.0.in2 2
setp mux8.0.in3 3
setp mux8.0.in4 4
setp mux8.0.in5 5
setp mux8.0.in6 6
setp mux8.0.in7 7
# The inputs to the mux4 component
net scale1 mux4.0.sel0 <= hm2_7i76e.0.7i76.0.0.input-20
net scale2 mux4.0.sel1 <= hm2_7i76e.0.7i76.0.0.input-21
# The inputs to the mux8 component
net mux8-sel0 <= hm2_7i76e.0.7i76.0.0.input-22
net mux8-sel1 <= hm2_7i76e.0.7i76.0.0.input-23
net mux8-sel2 <= hm2_7i76e.0.7i76.0.0.input-24
net mux8-sel0 => mux8.0.sel0
net mux8-sel1 => mux8.0.sel1
net mux8-sel2 => mux8.0.sel2
net mux-float conv-float-s32.0.in <= mux8.0.out
net mux-s32 <= conv-float-s32.0.out
net mux-s32 => select8.0.sel
net axis-select-x <= select8.0.out1
net axis-select-y <= select8.0.out2
net axis-select-z <= select8.0.out3
net axis-select-4 <= select8.0.out4
net axis-select-5 <= select8.0.out5
net axis-select-6 <= select8.0.out6
net axis-select-x => axis.x.jog-enable
net axis-select-y => axis.y.jog-enable
net axis-select-z => axis.z.jog-enable
# The output from the mux4 is sent to each axis jog scale
net mpg-scale <= mux4.0.out
net mpg-scale => axis.x.jog-scale
net mpg-scale => axis.y.jog-scale
net mpg-scale => axis.z.jog-scale
# The encoder output counts to the axis. Only the selected axis will move.
net encoder-counts <= hm2_7i76e.0.7i76.0.0.enc0.count
net encoder-counts => axis.x.jog-counts
net encoder-counts => axis.y.jog-counts
net encoder-counts => axis.z.jog-counts
3999
loadrt mux4 count=1
loadrt mux8 count=1
setp mux4.0.in3 0.1
setp mux8.0.in0 0
setp mux8.0.in1 1
setp mux8.0.in2 2
setp mux8.0.in3 3
setp mux8.0.in4 4
setp mux8.0.in5 5
setp mux8.0.in6 6
setp mux8.0.in7 7
Last edit: 23 Jan 2024 14:28 by Amin Laakel Sofet.
- Thank you received: 5934
23 Jan 2024 14:40 #291426
Replied by tommylight on topic My 7i76e Connection Sheet
In the main hal file, the loadrt line, does it set the board to mode 1 or mode 2?
Same line, does it have number of encoders at anything but 0?
Normally encoder 0 would be the spindle encoder, are you using that for MPG?
- Amin Laakel Sofet
24 Jan 2024 09:01 #291506
These are the loadrt lines that show up in the main Hal file.
We haven't fully configured the spindle encoder yet, because we were trying to figure out how to move the axis' with the MPG, is it possible that the encoder needs to be fully functional before we can use the MPG for the axis'?
Thanks in advance
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_eth board_ip="192.168.1.121" config="num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxx"
setp hm2_7i76e.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.s
Thanks in advance
loadrt hostmot2
24 Jan 2024 17:44 #291539
You would need mode 2 on the 7I76Es I/O section to enable the MPGs:
sserial_port_0=20xxxx
The following user(s) said Thank You: Amin Laakel Sofet
- Amin Laakel Sofet
26 Jan 2024 15:46 #291663
Thanks for the help we got the MPG to fully work after changing the mode to 20 and reconnecting some loose wires.
Time to create page: 0.157 seconds
