My 7i76e Connection Sheet
27 Sep 2020 10:21 #183962
by fons
Replied by fons on topic My 7i76e Connection Sheet
thankyou very much i will download it and install it again with 2.8
a quick question when a stepper motor had a torque of 12nm do it mean its the working torque or the holding torque and whats the relation between both
- Thank you received: 5935
27 Sep 2020 11:07 #183965
Replied by tommylight on topic My 7i76e Connection Sheet
Holding torque, working torque will decrease with rotational speed.
27 Sep 2020 13:59 #183980
by fons
got the linuxcnc 2.8 running i don't want the parralel poort config what is eazy to understand what to fill in where
for the pnconfig its not that clear anymore much more to fill in
i like to setup en 3axe mill with stepper motor nema17 and tb6600 driver limit switch single mpg for the 3axe (rotaryswitch) this is for now a test case
can i find somewhere a tutorial for these config ?
28 Sep 2020 22:54 #184228
by fons
do someone had make such a set up ? and can guide me one time true the pncconfig ?
what do i have to fill in where
what are the meaning of the variable and how inportant are they to do what ?
29 Sep 2020 06:57 - 29 Sep 2020 06:59 #184243
Replied by Aciera on topic My 7i76e Connection Sheet
I don't know of a tutorial. All the settings can later be changed in the created INI and HAL files or by rerunning the wizard.
Maybe best to ask about specific entries or do what you think is right and then post the INI and HAL files.
Last edit: 29 Sep 2020 06:59 by Aciera. Reason: Clarification
03 Oct 2020 05:34 #184664
by shariq
Replied by shariq on topic My 7i76e Connection Sheet
I need an arduino library for the Esp32 for this chip NVC7608DWR2G.
Please Help
Please Help
15 Oct 2020 20:42 #186231
by fons
i'm able to let the steppermotors run by linux cnc there is already a first live there
i like to add the mpg one for the 3 axis with a selection botton
ther is an example "mpg pendant" in the userguide on page 648 (v2.8) or page 540(v2.7) but here they talk about the parport how do i translate that to the mesa 7i76e cart
when i use the pncconfig i don't see simular names for the inputpins
how do i need to start ?
16 Oct 2020 08:19 #186262
If you search for my "spaceship plasma" thread in about p 3 or 4 there is a full worked example for the 7i76e
Replied by rodw on topic My 7i76e Connection Sheet
19 Oct 2020 22:34 #186630
by fons
maybe out off the topic
i have one set driver/motor hbs86H / 86HSE8.5N-B32 what i can controle perfect with the mesa 7i76e with time setting 4 times 5000
as an experiment i buy at aliexpress 3 TB6600 (40V/4A) low budget drivers and 3 nema17 steppermotor i see i need to change the time value to 4 times 50.000 what i also did the motors run good at low speed not at high speed they stop also with a high accelleration
i found nice old stepper phytron zss 80.200 2fase 4 coils 4V/5A for each coil place 2 by 2 in serie an try to let run only a low speed en very low accelleration
when i take an ociloscope and look at the output of the driver i see 2 nice square 90° shifted waves following the signale of the mesa output
how can i use the phytron steppermotor settings or something else what is wrong ?
- Stepping3D
- Thank you received: 3
31 Oct 2020 01:12 #187854
by Stepping3D
Replied by Stepping3D on topic My 7i76e Connection Sheet
Hi Everyone,
Just made some changes and adjustments to the work of others in this thread, so that the connector labels can be easily laser engraved. Changed fonts/text/spacing etc. to suit and make it easily readable. This was done in Rhino and converted to DXF so if you have any issues, just let me know., Hope it helps someone!
Time to create page: 0.642 seconds
