My 7i76e Connection Sheet
- Jakemestre1
- Thank you received: 3
09 Feb 2018 21:39 #105663
by Jakemestre1
Replied by Jakemestre1 on topic My 7i76e Connection Sheet
Norbert, Jan, Benb Rodw,
You guys are my heros! The wiring diagram and labels have helped so so much in building with the 7i76 I can't thank you guys enough. Anybody know how to get these onto the mesa website linked with the boards? That would be super useful as a first time user of mesa cards and linuxcnc.
Jake
Jake
09 Feb 2018 22:09 - 11 Feb 2018 23:19 #105666
by DanMN
Replied by DanMN on topic My 7i76e Connection Sheet
I agree - I just call the materials shared on this thread "The Manual". Honestly, I'd have stood zero chance of successfully wiring my system without the examples provided. The OEM doc gave me more questions than answers - it contains technical facts, didn't really express things in concrete terms. Picking apart Norbert's config taught me in days what would have otherwise required weeks of frustrating cross-referencing all over the web. It's been a much-appreciated lifesaver.
Last edit: 11 Feb 2018 23:19 by DanMN.
07 Jan 2019 10:46 #123689
by pl7i92
Replied by pl7i92 on topic My 7i76e Connection Sheet
amazing thank You
08 Jan 2019 18:02 #123782
by newbynobi
Replied by newbynobi on topic My 7i76e Connection Sheet
- xenon-alien
11 Jul 2020 20:13 - 11 Jul 2020 20:16 #174323
by xenon-alien
Replied by xenon-alien on topic My 7i76e Connection Sheet
Hello!
I'm new in MESA and LinuxCNC.
Can anybody tell me which bit file to use for this schematics?
I wont use serial 7i73 and will use a STEP/DIR servo motor for spindle.
I have only this bit files without other board number:
7i76e_7i76x3D
7i76e_7i76x1pD
7i76e_7i76x1D
7i76e_7i76x1_Dpl
Thanks!
Daniel
7i76e_7i76x3D
7i76e_7i76x1pD
7i76e_7i76x1D
7i76e_7i76x1_Dpl
Thanks!
Daniel
Last edit: 11 Jul 2020 20:16 by xenon-alien.
11 Jul 2020 20:37 #174327
Replied by PCW on topic My 7i76e Connection Sheet
You should not need to change the firmware unless you have parallel daughterboards
(or you want the Plasma specialized 7i76e_xxpl firmware)
- xenon-alien
11 Jul 2020 20:42 - 11 Jul 2020 20:47 #174328
by xenon-alien
You saying, that the needed firmware already on the board?
The standard, which I can use with the schematics from this topic?
(it will be a lathe, step/dir close-loop stepper on ZX and a step/dir close-loop srervo on the spindle + some functions from the schematics)
Last edit: 11 Jul 2020 20:47 by xenon-alien.
11 Jul 2020 20:52 #174330
Yes, the standard firmware will work
The following user(s) said Thank You: xenon-alien
09 Sep 2020 08:33 - 09 Sep 2020 08:52 #181398
by Adik A.
Replied by Adik A. on topic My 7i76e Connection Sheet
The wiring diagram is very helpful!
Simple questions. How to activate TB5 and TB6 outputs? I connected the estop to pin 4 (TB6). LinuxCNC shows error at startup:
24v connected to TB1 (24V - pin 5, GND - pin 8). 5V connected. One green LED lights up near the RJ45.
Mesa 7i76e is new, ordered from eusurplus.com/
Jumpers: W4, W6 - up, W7, W12 - down.
Attempting to flash the firmware does not change anything
In attachment hal, ini and log files.
Similar problem is described here:
www.cnc-club.ru/forum/viewtopic.php?f=158&t=8544&start=320
./LinuxCNC_DMM_servo.hal:35: Pin 'hm2_7i76e.0.7i76.0.0.analogin3' does not exist
adik@xu-linuxcnc:~$ uname -a
Linux xu-linuxcnc 5.6.19-rt12 #1 SMP PREEMPT_RT Tue Sep 8 15:49:09 CEST 2020 x86_64 x86_64 x86_64 GNU/Linux
mesaflash --device 7i76e --addr 10.10.10.10 --write 7i76e_7i76x1D.bit
Last edit: 09 Sep 2020 08:52 by Adik A..
- Thank you received: 5935
09 Sep 2020 08:58 #181400
Replied by tommylight on topic My 7i76e Connection Sheet
The error reffers to an analogue pin, is Mesa set to mode 1 or 2?
The following user(s) said Thank You: Adik A.
Time to create page: 0.130 seconds
