Mesa 7i76e - Joint 0/2 following error
16 Jul 2017 16:52 #95853
Replied by PCW on topic Mesa 7i76e - Joint 0/2 following error
Yeah, a USB/Ethernet adapter will not work for realtime Ethernet
(though its fine for normal Internet access so you could use it for that if your WIFI has issues)
Enabling/Disabling WIFI is done in Linux with the network manager
- JackBerkhout
- Topic Author
16 Jul 2017 19:22 #95857
by JackBerkhout
Replied by JackBerkhout on topic Mesa 7i76e - Joint 0/2 following error
Hi, I couldn't find the 'network manager', but did found
'Applications Menu' -> 'Settings' -> 'Network Connections', however I didn't find a way to disable WiFi.
Am I overlooking a menu item?
16 Jul 2017 19:29 #95858
I forget where the menu is on XFCE but I think its launched by one of the small top/bottom bar icons
17 Jul 2017 15:41 #95907
I have a feeling that the LinuxCNC Debian distribution doesn't have a graphical network manager. It's all done with awkward command-line stuff.
Replied by andypugh on topic Mesa 7i76e - Joint 0/2 following error
The following user(s) said Thank You: JackBerkhout
- JackBerkhout
- Topic Author
17 Jul 2017 17:02 - 17 Jul 2017 18:08 #95929
by JackBerkhout
Hi Andy, Thanks, I've done such in the past, fair enough.
I will look into it later, tomorrow I'm visiting my friends with the Emco lathe that I'm going to convert, need to do some preparations. I got the 180V DC motor driver (0-5V) from China, and like to hook it up.
They are good with the mechanics (they are building steam trains > 200kg), I have chosen to dive into LinuxCNC and doing the electronics.
My cousin asked me if I could help them out with something.
They had an Emco Compact 5 CNC with (partially?) failing electronics. Then they tried to resuscitate it with a car battery charger, poking the electrodes onto various places on several boards, but no help. It didn't make the electronics alive. Probably only some smoke signals, but no real rescue really...
After trying that, they asked me to come over have a look at it...
So after inspecting it, I decided to not use anything of the electronics and have let them remove all of it. But now it's my turn... choosing LinuxCNC, which I first have to learn. It's rather a project on its own...
Regards,
Jack.
Regards,
Jack.
Last edit: 17 Jul 2017 18:08 by JackBerkhout.
17 Jul 2017 23:27 #95949
Replied by rodw on topic Mesa 7i76e - Joint 0/2 following error
IF this is your PC, it does have wifi.
www.zotac.com/us/product/mini_pcs/ci320-nano
Are you using it?
The wifi should be a separate (mini) card inside the PC. Consider opening it up and just removing the card. Thats what I did so I was never tempted to try it again.
Are you using it?
18 Jul 2017 12:07 #95974
Yes, applying random voltages to random places is always the best way to fix things :-/
Any chance of exchanging the cousin for a less silly one?
- JackBerkhout
- Topic Author
18 Jul 2017 17:22 - 18 Jul 2017 17:31 #96005
by JackBerkhout
Hi Rod, you are totally correct!
It's not powerful, but I had it laying around.
Somehow I thought my mesa board would have WiFi, after reading I had to disable it, but of course later I understood this was regarding the PC.
Sometimes I still get the "Unexpected realtime delay on task 0", while WiFi isn't connected, but also (not yet) disabled.
By now I disabled the WiFi:
$ nmcli wifi
enabled
$ nmcli wifi off
$ nmcli wifi
disabled
This is persistent across reboots...
Let's see if I still get the error sometimes...
Thank you very much for helping me so much with LinuxCNC, I really can learn a lot here!
At the moment I have made advanced, thanks to you!
Kind regards,
Jack.
$ nmcli wifi
enabled
$ nmcli wifi off
$ nmcli wifi
disabled
Kind regards,
Jack.
Last edit: 18 Jul 2017 17:31 by JackBerkhout.
- JackBerkhout
- Topic Author
18 Jul 2017 17:28 - 18 Jul 2017 17:29 #96007
by JackBerkhout
Electronics has been my passion over the last 40 years, so you know how I feel when I inspect the electronics and hear him telling this story at the same time to indicate he did everything he could... Everyone has a strength, I believe. Obviously, electronics wouldn't quickly decide to make friends with him.
Last edit: 18 Jul 2017 17:29 by JackBerkhout.
- JackBerkhout
- Topic Author
18 Jul 2017 17:34 #96008
by JackBerkhout
BTW, we are close together, but I wasn't close when he attempted to force it to life.
Time to create page: 0.107 seconds
