ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
11 Jun 2023 09:48 - 11 Jun 2023 09:50 #273322 by deroj
Is there a quick way to install the #11-add-external-extensions?
git checkout and pip3 install ./ gives error.
seems like it deletes the temp files too early....
oj@debian:~/LiteX-CNC$ pip3 install ./
Processing /home/oj/LiteX-CNC
Installing build dependencies ... done
Complete output from command python setup.py egg_info:
File "<string>", line 1, in <module>
File "/usr/lib/python3.7/tokenize.py", line 447, in open
buffer = _builtin_open(filename, 'rb')
FileNotFoundError: [Errno 2] No such file or directory: '/tmp/pip-req-build-ox305jnb/setup.py'
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-req-build-ox305jnb/
FileNotFoundError: [Errno 2] No such file or directory: '/tmp/pip-req-build-i5bpps12/setup.py'
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-req-build-i5bpps12/
It is the DEBIAN 10 LinuxCNC 2.8.4 ISO
Last edit: 11 Jun 2023 09:50 by deroj.
30 Jun 2023 12:52 #274502 by romanetz
I made #11 to run using poetry
30 Jun 2023 13:07 #274505 by Pro_El
Hello all,
Can someone explain is 5A-75E board work now or still is work in progress as i presume
I wach this topic, but is quiet for some time..
I have two of this board so if someone need to test something i can do that..
github Peter-van-Tol is not updated from January, is it stoped development or is in other github project active??
github.com/Peter-van-Tol/LiteX-CNC/commits/main
01 Jul 2023 06:31 #274557 by romanetz
I've found a bug in existing software in "main" branch. When a stepgen is configured to 1000 pulses per millimeter, the user can set velocity 100 mm/sec, but not 150: driver reports inverted value of speed and position decreases according to this inverted speed. This leads to appearance of "joint following error" because the commanded speed differs from actual speed by sign. It seems that somewhere in the guts of the driver an overflow of unsigned integer appears therefore the speed is being inverted. I'm preparing the solution for this problem right now.
01 Jul 2023 06:42 #274558 by romanetz
Hello all,
Work on the project is in progress in another branch, github.com/Peter-van-Tol/LiteX-CNC/tree/...tensions-to-litexcnc
The way of configuration has changed: in this branch, the configuration is prepared during gateware (==the firmware of FPGA) compilation and upon start the driver fetches it from the FPGA. Also, the current state of firmware expects another structure of configuration JSON file. I appreciate any help regarding this issue as the new way of configuration is not documented yet.
The following user(s) said Thank You: Pro_El
03 Jul 2023 04:10 #274675 by tuxcnc
Can anyone force (11-add-external-extensions-to-litexcnc) an encoder to work ?
05 Jul 2023 13:37 #274830 by tuxcnc
Have you tried this?
litex-cnc.readthedocs.io/en/11-add-exter...modules/encoder.html
Yes.
I got some hal pins but values not change when encoder acts.
I need working hal configuration.
05 Jul 2023 13:57 #274831 by meister
some encoder needs pullup resistors
05 Jul 2023 15:50 - 05 Jul 2023 15:52 #274833 by tuxcnc
Most of encoders needs pullups.
These have built-in can burn 3.3 V inputs...
I always use pullups and Schottky diodes.
Last edit: 05 Jul 2023 15:52 by tuxcnc.
Moderators: PCWjmelson
Time to create page: 0.181 seconds
