ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
30 Dec 2023 09:03 #289364
by Ehsan_R
Replied by Ehsan_R on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Hello
Can I use this firmware and driver for 5A-75E8.2 (version 8.2)?
30 Dec 2023 13:50 - 30 Dec 2023 13:55 #289377
by Mecanix
Replied by Mecanix on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
oops, wrong thread. misleading. ([delete])
Last edit: 30 Dec 2023 13:55 by Mecanix.
30 Dec 2023 14:32 #289381
by TOLP2
Replied by TOLP2 on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Yes, you can! Use the version 6.0 as board version, it has the same pinout.Hello
05 Jan 2024 21:14 #289903
by Ehsan_R
I have just joined the LinuxCNC community and as my first experience working with LinuxCNC software, I plan to use an 5A-75E8.2 board and LiteX-CNC.
Therefore, I request users who have worked with this board to share with me a complete example of how to configure their Hal and INI files.
And also guide me on how to get encoder values and create a closed loop system for each axis.
Many thanks
Many thanks
08 Apr 2024 11:05 #297801
by wzor
Replied by wzor on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Is the project still alive? No movement for three months(
- Thank you received: 5934
08 Apr 2024 11:13 #297802
Replied by tommylight on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
3 github links on at the start of this topic, 1 was updated 3 weeks ago, 1 a month ago, and on seems nothing changed for 2 years.
forum.linuxcnc.org/27-driver-boards/4442...board?start=0#228191
So it is still alive, although if stuff is working properly, there would be need for changes.
08 Apr 2024 12:06 #297805
by cornholio
Replied by cornholio on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Most of these projects are helped along by others finding an issue or coming up with improvements, suggestions or additions.
If the project is in a solid working state sometimes it won’t “progress”, especially if the developer has it a point that it’s working for them.
Take the mesa firmware code base, going by the code released it doesn’t get updated often but works fine. The most recent updates are to support the change of FPGA brand.
At the end of the day it comes down to users being active in a project, one guy can’t be expected to do everything.
Time to create page: 0.175 seconds
