ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
01 Aug 2023 15:32 #276706
by cornholio
Replied by cornholio on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
If you use the main branch you should be ok.
That's a known issue with the 11-add-external-extensions-to-litexcnc branch. It happens on both 2.8 & 2.9 branches of Linuxcnc.
The best idea will be to keep a watch on this thread:
github.com/Peter-van-Tol/LiteX-CNC/issues/28
21 Sep 2023 02:45 #281272
by DHeineck
Replied by DHeineck on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Dredging this one out of the archives -- how are people getting on with this hardware/firmware solution? I'd love to play around with this on a 3020 router with your usual steppers, limit sensors, EMO, and maybe a 0-10V for spindle. Is there a config that works for this use case?
21 Sep 2023 03:49 - 21 Sep 2023 05:03 #281276
by cornholio
Pete's been making some great progress. He's working on a SPI version for the RPi for those that want that option.
I'm just uploading an image for the RPi with LitexCNC drivers and tools to build firmware, yes it does include Linuxcnc v2.9.
If you wander over to github.com/Peter-van-Tol/LiteX-CNC and read the discussions section you'll find out more.
Link to image. User name & passwd in text file in google drive folder
drive.google.com/file/d/1PvfQPvsrcP9Ss2Z...A4P/view?usp=sharing
Last edit: 21 Sep 2023 05:03 by cornholio. Reason: add link
22 Sep 2023 06:47 #281350
by deroj
Replied by deroj on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Yes. It is working very good. Maybe perfect
I use it for my lathe and for a 3 axis mill.
pwm output is used to generate 0-10V signal for the vfd of the mill.
on the lathe I use a 10.000ppr spindle encoder with high frequency optocouplers, which works perfect.
G76, G33 cycles and constant surface speed - no problems.
Finished already about 400 parts on my lathe. And this with a buggy version of litexcnc. And this bug is solved now
Peter did a great job the last weeks
22 Sep 2023 10:02 #281360
by deroj
Please fell free to download my maschine setup.
It includes the setup for my lathe.
There are 4 stepgens available.
2 Encoders with A, B, Z inputs
3 PWM channels
general GPIOs
Communication to VFD via modbus, mb2hal component.
in the firmware folder are the config JSON and the prebuilt bitfile.
It uses colorlight 5A-75B board
Ip address 192.168.178.150
You can add or change to your needs. Think this is a good basic to start.
3 PWM channels
general GPIOs
22 Sep 2023 17:15 #281395
by DHeineck
Thank you both for the update! (and Peter, for that matter)
The following user(s) said Thank You: TOLP2
16 Oct 2023 19:23 #283138
by TOLP2
Replied by TOLP2 on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
I took the development of Litex-CNC to a
new topic
.Feel free to post suggestions and questions in that topic, or post them on the
Github Discussions
The following user(s) said Thank You: tommylight, svb
18 Dec 2023 16:34 - 18 Dec 2023 16:57 #288492
by horcsab
Replied by horcsab on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Hi All,
Please help me!
I setup fresh install Linuxcnc 2.9.1. (on laptop i7 x64)
Linux cnc 6.1.0-13-rt-amd64 #1 SMP PREEMPT_RT Debian 6.1.55-1 (2023-09-29) x86_64 GNU/Linux
I would like setup Litexcnc, but it dosen't work. If runing litexcnc install_toolchain command, i get this error:
INFO: Successfully installed Litex in '/opt/litex'
INFO: Auto-detected os linux.
INFO: Auto-detected architecture i386.
ERROR: OSS-Cad-Suite does not support `i386` architecture.
ERROR: Please use a different system to build the firmware.
What can be the problem?
(sorry my bad english)
Please help me!
Last edit: 18 Dec 2023 16:57 by horcsab.
- Thank you received: 5966
18 Dec 2023 17:36 #288497
Should be a Debian issue, had something similar happen with Debian 12.0 but not on Debian 12.2 and later.
Might want to look on Debian forums for this.
Replied by tommylight on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Strange, it is trying to use OSS for i386 systems on a 64 bit Linux.I setup fresh install Linuxcnc 2.9.1. (on laptop i7 x64)
Time to create page: 0.168 seconds
