ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
18 Dec 2023 18:17 - 18 Dec 2023 18:20 #288504
by Mecanix
$ mkdir oss-cad
$ cd oss-cad
$ wget github.com/YosysHQ/oss-cad-suite-build/r...nux-x64-20231017.tgz
$ tar -xvf oss-cad-suite-linux-x64-20231017.tgz
$ export PATH="/home/user/path-to/oss-cad-suite/bin/:$PATH"
Replied by Mecanix on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Until the maintainer of Litex-cnc look into this (have you reported it on github?), you can install OSS-cad manually to get you going. Ensure your path is set.
$ mkdir oss-cad
$ cd oss-cad
Last edit: 18 Dec 2023 18:20 by Mecanix.
18 Dec 2023 18:20 #288505
by jmelson
Replied by jmelson on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
You cannot run LinuxCNC on a 386, the memory model is different on the 386 from the 486, Pentium, etc. CPUs. But, you say it is an X64 i7 CPU. Something must have gotten seriously fouled up during the OS install, or during the setup for the OSS-Cad-Suite.
Jon
Jon
19 Dec 2023 04:24 #288542
by KlimukVI
Replied by KlimukVI on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Try this:
litexcnc install_toolchain --user --architecture x64 --os linux
The following user(s) said Thank You: horcsab
19 Dec 2023 07:54 - 19 Dec 2023 08:29 #288555
by horcsab
Replied by horcsab on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
I try this method, but no working...
$ mkdir oss-cad
$ cd oss-cad
$ wget github.com/YosysHQ/oss-cad-suite-build/r...nux-x64-20231017.tgz (I updated the name)
And I try this:
It's work!!!
$ mkdir oss-cad
$ cd oss-cad
And I try this:
It's work!!!
Last edit: 19 Dec 2023 08:29 by horcsab.
20 Dec 2023 15:20 - 20 Dec 2023 15:21 #288665
by horcsab
So, next problem..
I try flashing the FPGA (5A-75E v8.0) widt FT2232 modul, but always get this error:
nc@cnc:~/Downloads/proba2$ openFPGALoader -d /dev/ttyUSB0 -f prob.bit
write to flash
Jtag frequency : requested 6.00MHz -> real 6.00MHz
mpsse_write: fail to write with error -1 (usb bulk write failed)
mpsse_read: fail to flush buffer with error: -1 (usb bulk write failed)
JTAG init failed with: Unknown device with IDCODE: 0x1954fc56 (manufacturer: 0x62b (), part: 0x4a vers: 0x1
What is the problem?
write to flash
Last edit: 20 Dec 2023 15:21 by horcsab.
20 Dec 2023 16:44 - 20 Dec 2023 16:46 #288673
by Mecanix
Prolly just because ya forgot to make a wish and didn't crossed your fingers... stuff's picky sometimes.
$ sudo openFPGALoader --unprotect-flash -c ft232 -f prob.bit
Last edit: 20 Dec 2023 16:46 by Mecanix.
20 Dec 2023 17:18 #288676
by horcsab
I tried but no change. (I see the /dev/ttyUSB0..3 the ftdi2232 modul)
write to flash
unable to open ftdi device: -3 (device not found)
JTAG init failed with: unable to open ftdi device
If I try this:
$ sudo openFPGALoader --unprotect-flash -c ft2232 -f prob.bit
write to flash
$ sudo openFPGALoader --unprotect-flash -d /dev/ttyUSB0 -f prob.bit
write to flash
JTAG init failed with: Unknown device with IDCODE: 0x8d1d2c56 (manufacturer: 0x62b (), part: 0x68 vers: 0x8
write to flash
If I try this:
write to flash
write to flash
20 Dec 2023 17:53 - 20 Dec 2023 17:56 #288680
by Mecanix
If it doesn't take the -c ft232 argument I suspect there is a driver issue.
$ sudo dmesg | grep FTDI
Post output. And while there enable --verbose-level=2 (or 3, forgot)
Last edit: 20 Dec 2023 17:56 by Mecanix.
20 Dec 2023 17:58 #288681
by horcsab
I'll try it tomorrow.
May be necessary external resistor? (4.7k)
TCK = Pull-down
TMS = Pull-up
TDI = Pull-up
TDO = Pull-up
TCK = Pull-down
TMS = Pull-up
TDI = Pull-up
TDO = Pull-up
20 Dec 2023 18:06 #288683
by Mecanix
No pullup/down required. Straight up ft232's AD0~AD03 to jtag inputs. Inserting a fully functional ft232/driver output below for your ref. Good luck with making this work.
cnc@debian:~$ sudo dmesg | grep FTDI
[204748.812327] usb 1-1.4: Manufacturer: FTDI
[204748.843937] usbserial: USB Serial support registered for FTDI USB Serial Device
[204748.843970] ftdi_sio 1-1.4:1.0: FTDI USB Serial Device converter detected
[204748.848687] usb 1-1.4: FTDI USB Serial Device converter now attached to ttyUSB0
cnc@debian:~$
cnc@debian:~$
Time to create page: 0.138 seconds
