ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
10 Mar 2022 15:20 #236853
by vre
Replied by vre on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Which are correct files for 5A-75E v8 board ?
10 Mar 2022 22:09 #236898
by TOLP2
Replied by TOLP2 on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
With thanks to cncwhacko I finally got the board working. The problem had two layers:
- Windows was incorrectly configured for directly talking to the card on the given IP-address. I had to assign the PC an IP-address in the same subnet manually under the IPv4 settings. I.e. when the card has 192.168.1.20 as an address, the PC should get something in the range of 192.128.1.### with a subnet of 255.255.255.0 (or /8). After this change, the .svf-file as supplied by cncwhacko worked.
- Part deux: my own Hello world version still didn't work. This was I think due to the flag with_hw_init_reset=False which was not set.
12 Mar 2022 15:30 #237005
by cncwhacko
Replied by cncwhacko on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Great to hear you got it responding on the network!
I tried pulling in your package with VS Code and created the docker envs from within, still dont know how to access the actual linuxcnc container, do you have a run through of how to do that?
I also played with ice studio a little bit to see what your current stepper verilog looks like. Currently shows a syntax error in the very last block but it doesnt look like one as far as I can tell. Did you source that from somewhere else?
12 Mar 2022 21:51 - 14 Mar 2022 08:28 #237025
by TOLP2
First a quick check question: did you install the Remote containers plugin in VSCode? With this plugin you can easily start the container and use the VS Code terminal to interact with the container. For more information see the
documentation
I have improved the container (available on GitLab). I've put oss-cad-suite and LinuxCNC on the path.:
- Building firmare:
- cd to the root (workspace);
- type python3 -m firmware <config-file>
- the output will be placed in a folder with the name of the config-file, cd to this folder and then to gateware, i.e. /workspace/<config-name>/gateware
- in this folder run chmod +x build_<cardname>.sh followed by ./build_<cardname>.sh;
- use your tool of choice to load the image to the card.
- Testing:
- You can test the firmware and driver with halrun;
- Start testing with the following command sequence:
- loadrt litexcnc
- loadrt litexcnc_eth config_file=<path_to_config_file>
- loadrt threads name1=servo-thread period1=100000 fp1=1
- addf <card_name>.0.read servo-thread
- addf <card_name>.0.write servo-thread
- show pin
- show function
- start
Last edit: 14 Mar 2022 08:28 by TOLP2. Reason: Solved typo in the code (thanks to cncwhacko)
- Thank you received: 5961
12 Mar 2022 22:31 #237035
Replied by tommylight on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Someone ... (missed it ),
Please do not change the subject when replying, it makes a mess with the database and whoever is trying to help.
Thank you.
If anyone needs to change the title, ask us mods/admins so we can change it for the entire topic.
soooo What should the tittle of this topic be ?
Thank you.
13 Mar 2022 15:34 #237117
by cncwhacko
I think something along the lines of "Discussion of Colorlight 5A-75E/5A-75B as FPGA controller board" would be more descriptive.
13 Mar 2022 16:25 #237128
Done, thank you.
Removed "discussion" as this is a discussion board so it is redundant, and added "colorcnc" so it can be found by those who have not been here lately.
13 Mar 2022 21:18 - 13 Mar 2022 21:19 #237146
by cncwhacko
thank you! I was able to get the dev env working locally, this will be handy for testing thing out.
i found a few typos in your testing notes:
loadrt litexcnc_etch config_file=<path_to_config_file>
should be
and then:
loadrt threads name1=servo-thread period=100000 fp=1
should be
would <board_name> in my case be something like, `colorlight_5a_75e` ? its not super clear where thats defined.
should be
and then:
should be
Last edit: 13 Mar 2022 21:19 by cncwhacko.
The following user(s) said Thank You: TOLP2
14 Mar 2022 08:26 #237193
by TOLP2
I typed those commands as I remembered, my apologies for the typos. For clarity, I updated the typos in the original post.
Regarding the <board-name>, this is defined in the JSON file with the tag "name". However, I discovered that it is hard-coded to 'test' at this moment. Tonight I will update this to use the correct name. In halcmd it is quiet easy to retrieve the board name, after adding the board withYou can retrieve the functions withThis tells you which functions can be added to the thread and you could derive the board-name from this output.
show function
14 Mar 2022 16:25 #237212
by cncwhacko
awesome, thank you! I see the section where test name is hardcoded--I am new to C so am dangerous at this point ;-D, but was able to see it connect to the board over my network from the container.
I am going to attempt to replace a few of the buffers and test inputs/outputs on the board. Just purchased a hot air rework station so that will be another fun thing to try out.
Time to create page: 0.334 seconds
