- Hardware & Machines
- Driver Boards
- [SOLVED]How to configure the PWM signal in a MESA 7i96 for a spindle?
07 Mar 2022 19:54 - 13 May 2022 19:48 #236597
by Nest
Hi, i have my CNC almost finished, in the absence of configuring the spindle.
My spindle work with a PWM signal, the output pin of my MESA 7i96 go to imput pin of my electronic and my electronic makes it spin.
Which is the ping of my MESA for a signal PWM and how to configure it?
Thanks you so much
Thanks you so much
Last edit: 13 May 2022 19:48 by Nest.
07 Mar 2022 20:16 #236600
Replied by PCW on topic How to configure the PWM signal in a MESA 7i96 for a spindle?
There is 7I96 firmware that replaces stepgen4's Step/Dir signals
with a PWMGens PWM/Dir : 7i96d_1pwm.bit
JTs 7i96 configuration utility knows how to setup the PWMGen
07 Mar 2022 21:17 #236603
by Nest
Replied by Nest on topic How to configure the PWM signal in a MESA 7i96 for a spindle?
in port 4 there are 6 pins, do you know which are the two pins where I have to place the positive and negative cable?
07 Mar 2022 22:51 #236610
It depends on what your spindle drive expects.
7I96 connections are:
TB2:
1 GND
2 PWM-
3 PWM+
4 DIR-
5 DIR+
6 5V
TB2:
1 GND
2 PWM-
3 PWM+
4 DIR-
5 DIR+
6 5V
07 Mar 2022 23:25 #236616
by Nest
ok, my electronic of spindle work with two cables, i think i have to connect the cable red in the PIN 3 (PWM+) and the cable black in PIN 1 (GND) or PIN 2 (PWM-)
what you you think?
what you you think?
08 Mar 2022 00:23 #236619
Do you have a link to the spindle drive manual?
09 Mar 2022 20:43 #236781
by Nest
- robertspark
- Thank you received: 216
09 Mar 2022 21:24 #236785
by robertspark
The following user(s) said Thank You: PCW
09 Mar 2022 21:59 - 09 Mar 2022 22:03 #236787
OK so its a simple OPTOCoupler input so I would wire it:
7I96 Spindle PWM
1 GND PWM-
2 PWM- PWM+
And then invert the PWM output on the 7I96:
setp hm2_7i96.0.pwmgen.00.out0.invert_output true
(The reason for using the 7I96's PWM- is so PWM is 0V at startup and LinuxCNC stop)
7I96 Spindle PWM
1 GND PWM-
2 PWM- PWM+
Last edit: 09 Mar 2022 22:03 by PCW.
14 Mar 2022 18:56 #237224
by Nest
hi. I have connected the cables as you say but it does not work, when I run LinuxCNC the spindle is activated and does not stop
how do I have to configure PncConf?
- Driver Boards
Time to create page: 0.254 seconds
