- Hardware & Machines
- Driver Boards
- [SOLVED]How to configure the PWM signal in a MESA 7i96 for a spindle?
11 Apr 2022 21:37 #239980
Replied by PCW on topic How to configure the PWM signal in a MESA 7i96 for a spindle?
At the minimum. you would need to link the software PWM output pin in
hal to the SSR used for PWM output.
11 Apr 2022 22:36 #239986
by Nest
Replied by Nest on topic How to configure the PWM signal in a MESA 7i96 for a spindle?
Ok, but what is the pin? I have tested all of them and it doesn't work.
I'm sure it's easy but I don't see it
11 Apr 2022 22:52 #239992
pwmgen.0.pwm
so for example
net myslowpwm pwmgen.0.pwm hm2_7i96.0.ssr.00.out-03
so for example
12 Apr 2022 07:13 #240019
by Nest
hi, i have tested it but no work
12 Apr 2022 13:58 #240046
It does work but you need to setup the PWMGen parameters and connect the
required PWM pins
Did you read the pwmgen manual page?
Can you post you current hal file here?
required PWM pins
12 Apr 2022 19:22 #240074
by Nest
Hi, well it's already solved, I followed this manual
linuxcnc.org/docs/2.8/html/examples/spindle_en.html
The problem I had was in the parameters. Now I have another problem, I have broken the optocoupler of the spindle electronics, I did not realize it and it connects 5v directly from the source and I did not put a limiting resistor on it and I have broken the diode, tomorrow I will buy a replacement to repair it ;(
19 Apr 2022 17:11 #240668
by Nest
Hi, good day everyone, sorry by delay i'm had very work.
I repair my electronic of spindle, i have change the optocoupler and at now my spindle work fine, better than i used the previous port (TB1/TB2 port 4)
but at now i want to use the other port TB3 (output 1) for other PWM signal, i want to install a laser of 20W.
I have add other spindle at the HAL in the linerMAX_SPINDLES = 2 in the archive .INI
It's generated other PINS whit the spiendle 1
I configure all like spindle 0 but changeing few names custom.
Whe i try run the spindle 1 with command M3 S1000 $1 the menssage the LinuxCNC is invalid spindle number in spindle speed command
Can someone help me
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS num_spindles=[EMCMOT]MAX_SPINDLES
Can someone help me
21 Apr 2022 19:07 #240807
by Nest
Hi i'm stuck, can someone help me to set two spindles?
thank you
thank you
- Thank you received: 5984
21 Apr 2022 21:36 #240816
Replied by tommylight on topic How to configure the PWM signal in a MESA 7i96 for a spindle?
Upload here the hal and ini files, please.
The following user(s) said Thank You: Nest
21 Apr 2022 22:29 #240829
by Nest
Ok, thanks you so much
- Driver Boards
Time to create page: 0.291 seconds
