- Hardware & Machines
- Driver Boards
- [SOLVED]How to configure the PWM signal in a MESA 7i96 for a spindle?
14 Mar 2022 19:01 #237225
Replied by PCW on topic How to configure the PWM signal in a MESA 7i96 for a spindle?
Did you add the:
setp hm2_7i96.0.pwmgen.00.out0.invert_output true
statement to the hal file?
14 Mar 2022 19:12 - 14 Mar 2022 19:13 #237226
by Nest
Replied by Nest on topic How to configure the PWM signal in a MESA 7i96 for a spindle?
No, where do I have to add it? where in the hall file?
forgive my poor knowledge in linuxcnc
Last edit: 14 Mar 2022 19:13 by Nest.
14 Mar 2022 19:44 #237229
it can be added anywhere in the hal file
(probably best in the spindle section for clarity)
15 Mar 2022 18:14 - 15 Mar 2022 18:15 #237352
by Nest
Last edit: 15 Mar 2022 18:15 by Nest.
15 Mar 2022 18:30 #237356
Did you install firmware that has a PWMgen?
7i96d_1pwm.bit Is the firmware that uses the last stepgen connection
as a PWM output
as a PWM output
15 Mar 2022 18:50 #237358
by Nest
if I use that firmware linuxcnc generates an error
15 Mar 2022 19:40 #237363
What is the error?
15 Mar 2022 19:54 #237366
by Nest
15 Mar 2022 20:01 #237368
Can you start LinuxCNC from the command line
and copy paste the error here?
15 Mar 2022 21:42 #237383
by Nest
ok, i go to copy paste the file linuxcnc.report here
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.2-11-g6a3d0a434
Machine configuration directory is '/home/nest/linuxcnc/configs/CNC3040Z-DQ'
Machine configuration file is 'CNC3040Z-DQ.ini'
INIFILE=/home/nest/linuxcnc/configs/CNC3040Z-DQ/CNC3040Z-DQ.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./CNC3040Z-DQ.hal
Running HAL shutdown script
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 192.168.1.121: INFO: Hardware address (MAC): 00:60:1b:16:02:07
hm2_eth: discovered 7I96
hm2/hm2_7i96.0: Low Level init 0.15
board fails HM2 registration
hm2_eth: in hm2_eth_reset
hm2: unloading
Debug file information:
Note: Using POSIX realtime
hm2/hm2_7i96.0: config.num_stepgens=5, but only 4 are available, not loading driver
hm2/hm2_7i96.0: failed to parse Module Descriptor 4
hm2_eth: rtapi_app_main: Invalid argument (-22)
./CNC3040Z-DQ.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth
./CNC3040Z-DQ.hal:9: /usr/bin/rtapi_app exited without becoming ready
./CNC3040Z-DQ.hal:9: insmod for hm2_eth failed, returned -1
1120
Stopping realtime threads
Unloading hal components
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
http://pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: mar mar 15 21:37:08 WET 2022
UTC Date: mar mar 15 21:37:08 UTC 2022
this program: /usr/bin/linuxcnc_info
uptime: 21:37:08 up 2 min, 1 user, load average: 1,35, 1,24, 0,54
lsb_release -sa: Debian Debian GNU/Linux 10 (buster) 10 buster
which linuxcnc: /usr/bin/linuxcnc
pwd: /home/nest/linuxcnc/configs/CNC3040Z-DQ
USER: nest
LOGNAME: nest
HOME: /home/nest
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: lightdm-xsession
display size: 1920x1080 pixels (508x285 millimeters)
PATH: /usr/bin:/home/nest/linuxcnc/configs/CNC3040Z-DQ/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: linuxcnc
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT RT Debian 4.19.208-1 (2021-09-29)
machine -m: x86_64
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-4.19.0-18-rt-amd64 root=UUID=d8d1ad22-76ae-49c2-b593-5cb7c4750291 ro initrd=/install/initrd.gz quiet
model name: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
cores: 4
cpu MHz: 1603.852
parport: 0000-0000 : parport0
serial: 0000-0000 : serial
Versions:
gcc: gcc (Debian 8.3.0-6) 8.3.0
python: Python 2.7.16
git: git version 2.20.1
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
glade-gtk2: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.8.2-11-g6a3d0a434
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
dpkg -l '*linuxcnc*':
Deseado=desconocido(U)/Instalar/eliminaR/Purgar/retener(H)
| Estado=No/Inst/ficheros-Conf/desempaqUetado/medio-conF/medio-inst(H)/espera-disparo(W)/pendienTe-disparo
|/ Err?=(ninguno)/requiere-Reinst (Estado,Err: mayúsc.=malo)
||/ Nombre Versión Arquitectura Descripción
un linuxcnc <ninguna> <ninguna> (no hay ninguna descripción disponible)
un linuxcnc-dev <ninguna> <ninguna> (no hay ninguna descripción disponible)
un linuxcnc-doc <ninguna> <ninguna> (no hay ninguna descripción disponible)
ii linuxcnc-doc-en 1:2.8.2.11.g6a3d0a434 all motion controller for CNC machines and robots (English documentation)
ii linuxcnc-doc-es 1:2.8.2.11.g6a3d0a434 all controlador de movimiento para máquinas CNC y robots (Español).
ii linuxcnc-doc-fr 1:2.8.2.11.g6a3d0a434 all motion controller for CNC machines and robots (French documentation)
un linuxcnc-sim <ninguna> <ninguna> (no hay ninguna descripción disponible)
un linuxcnc-sim-dev <ninguna> <ninguna> (no hay ninguna descripción disponible)
ii linuxcnc-uspace 1:2.8.2.11.g6a3d0a434 amd64 motion controller for CNC machines and robots
ii linuxcnc-uspace-dev 1:2.8.2.11.g6a3d0a434 amd64 PC based motion controller for real-time Linux
- Driver Boards
