Transformer isolation outputs
05 Feb 2024 06:31 #292487
by DSS
Transformer isolation outputs was created by DSS
While looking at options to add a few isolated outputs to my 7i92th. I recalled a post by PCW "
here
" saying the SSR module is for transformer isolation. Sounds interesting.
After reading the hostmot2 SSR section of the docs and taking a close look at my 7i96s as a reference. I think I have a grasp on how this is being done. However I do have a few questions.
I assume the line driver / buffer protects the fpga pins and can better drive the primary coil. Is a inverted output line driver / buffer required or would a non inverted IC work the same?
How critical is capacitor value? I was unsure how to properly calculate the values for the primary and secondary transformer capacitors.
Here is what I came up with for adding a few SSR outputs to my 7i92th (heavily 7i96s influenced). I wanted to get some feedback before routing the board traces and ordering a pcb. Some components differ from what is on my 7i96s, I am just trying to use what I have on hand. I can however make changes if I have made poor component selections.
Thank you in advance for your advice.
- Thank you received: 5934
05 Feb 2024 12:45 #292504
Replied by tommylight on topic Transformer isolation outputs
You should wait for PCW to confirm this, but i am pretty sure transformers can not be used for DC signaling.
Think of SSR as an LED with a photo transistor in a box, so fully isolated and controled with light. When LED turns on it makes photo transistor conduct current, when off no current passing through transistor.
There are a lot of SSR types, DC ones with transistors and AC ones with Thyristors/Triacks, being main groups. AC ones will not switch off when the input is set from high to low, they must cross through 0 on the output side to switch off.
05 Feb 2024 16:15 #292530
Replied by PCW on topic Transformer isolation outputs
That looks right except the capacitor values (we use 0.1 uF for the non isolated side and 1000 pF for the isolated side)
inverted or non-inverted work the same
Not really safe to drive the xfrmer with the direct FPGA outputs (plus it would only be 3.3V vs 5V)
The following user(s) said Thank You: DSS
05 Feb 2024 23:23 - 05 Feb 2024 23:32 #292593
by DSS
That was my first thought as well. Then after reading the ssr section of the docs I realized it was using pwm. Reminds me of a half bridge transformer coupled gate drive circuit. With only the one mosfet as our output instead of flip flopping two.
Thank you for the schematic review and value recommendations. That makes sense, I don't know why I forgot about the fpga being 3.3v. I need to be more mindful of that.
On the hostmot2 side of things does this act like a single ended gate drive with just the one pwm signal. Or more like a double ended setup with two opposite polarity pwm signals?
Replied by DSS on topic Transformer isolation outputs
Last edit: 05 Feb 2024 23:32 by DSS. Reason: formatting
06 Feb 2024 01:36 #292605
Basically just two square waves, the reference
and the outputs. When off the outputs are in phase
with the reference, when on, the outputs are 180
degrees relative to the reference.
07 Feb 2024 09:30 - 07 Feb 2024 09:32 #292722
by DSS
@PCW Thanks for confirming. That is how I understood the ssr man page but was not 100% sure.
This is what I have at this point. A simple daughter (little-sister ? lol) board. Measuring roughly 50x50 with direct din mounting, pluggable terminal blocks and idc header. The DSS-SSR4 gives me x4 additional isolated SSR outputs. I really like the 7i92+g540 combo for simple systems. However I often need just a few more outputs then the two onboard the g540 and not all systems warrant a full daughter card.
After I have a chance to assemble / test the board, I will be putting all of the documentations and source files on my GitHub acct.
Last edit: 07 Feb 2024 09:32 by DSS.
23 Feb 2024 09:23 - 23 Feb 2024 09:44 #294055
by DSS
One of these days I will finish my re-flow oven. Soldering would have gone much faster and come out cleaner if I was not doing it by hand. Test board assembled and ready to hook up to my Mesa 7i92th. I am not sure how I missed it, but you can see the idc hdr needs to be rotated 180*. This has no functional benefit but will ease ribbon cable routing in my electrical cabinet (no twist in ribbon).
Last edit: 23 Feb 2024 09:44 by DSS. Reason: editor problems; spliting post.
23 Feb 2024 09:43 #294059
by DSS
And one custom Bin file later. It's Alive ! haha I will need to fix a few simple errors such as silkscreen, hdr orientation ect. Otherwise we have transformer isolated outputs; how cool
Video does not want to embed properly; lets try a link. " Video "
In regards to the Bin file: @PCW after synthesizing in Efinity, within the Result tab under Interface. I get a "Unassigned Core Pins: 2" error. Otherwise no problems and the file flashes and functions exactly as expected. I am new to the Efinity IDE and was unsure if that was a result of my new pin vhd work.
23 Feb 2024 21:26 #294121
The unassigned core pins are probably TP0 and TP1,
leftovers from performance testing. I haven't bothered
to remove them yet, the message is harmless.
04 Apr 2024 23:46 - 04 Apr 2024 23:47 #297611
by DSS
I have the board about where I want it for my use case. I will be organizing my files and posting to GitHub shortly.
Last edit: 04 Apr 2024 23:47 by DSS.
The following user(s) said Thank You: hardware_crash
Time to create page: 0.108 seconds
