Create a FPGA board for raspberry
- Boaschti
- Topic Author
4 years 10 months ago #228341
by Boaschti
Create a FPGA board for raspberry was created by Boaschti
Hello, i plan to create a custom I/O like the mesa 7c80. My problem is that mesa cards are not available at this time and i need relais on board.
We have much experience with electronics.
Now i have seen the post from gtt38 Link with a running fpga eval board and a raspberry.
My questions are:
Are there any layouts available with a fpga and raspberry?
When using the fpga board Link :
Are there any more informations about using universal FPGA Boards?
Do i need any modifikations in hostmot2 firmware?
Do i need any modifikations on the eval board?
Are there any showbreakers which i don't know yet (like closed sources or unknown code or fpga firmware modifications)? (Except normal showbreakers with electronic components...)
Best regards.
My questions are:
Best regards.
- Henk
- Thank you received: 92
4 years 10 months ago #228346
by Henk
Replied by Henk on topic Create a FPGA board for raspberry
This came up recently. Looks interesting.
- Bari
- Thank you received: 234
4 years 10 months ago #229097
by Bari
Replied by Bari on topic Create a FPGA board for raspberry
forum.linuxcnc.org/27-driver-boards/44422-colorcnc
"ColorCNC" because it's a firmware driver for Chinese board Colorlight 5A-75B
www.colorlightinside.com/Products/i%20Re...ng-series/34_25.html
Sells for ~$15
Sells for ~$15
- Boaschti
- Topic Author
4 years 9 months ago - 4 years 9 months ago #232477
by Boaschti
Replied by Boaschti on topic Create a FPGA board for raspberry
Is it possible to make a custom .bit File with following IO pinout. Of course without having trouble with FPGA stability.
The basic pinout is form 7c80 board and i need some extensions.
See attachment for or
Configuration pin-out:
IO Connections for StepGens+Misc
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
0 0 IOPort StepGen 0 Step/Table1 (Out)
0 1 IOPort StepGen 0 Dir/Table2 (Out)
0 2 IOPort StepGen 1 Step/Table1 (Out)
0 3 IOPort StepGen 1 Dir/Table2 (Out)
0 4 IOPort StepGen 2 Step/Table1 (Out)
0 5 IOPort StepGen 2 Dir/Table2 (Out)
0 6 IOPort StepGen 3 Step/Table1 (Out)
0 7 IOPort StepGen 3 Dir/Table2 (Out)
0 8 IOPort StepGen 4 Step/Table1 (Out)
0 9 IOPort StepGen 4 Dir/Table2 (Out)
0 10 IOPort StepGen 5 Step/Table1 (Out)
0 11 IOPort StepGen 5 Dir/Table2 (Out)
0 12 IOPort SSerial 0 RXData0 (In)
0 13 IOPort SSerial 0 TXData0 (Out)
0 14 IOPort SSerial 0 TXEn0 (Out)
0 15 IOPort QCount 0 Quad-A (In)
0 16 IOPort QCount 0 Quad-B (In)
0 17 IOPort QCount 0 Quad-IDX (In)
0 18 IOPort PWM 0 PWM (Out)
0 19 IOPort PWM 0 /Enable (Out)
0 20 IOPort None
0 21 IOPort None
0 22 IOPort InMux 0 Addr0 (Out)
0 23 IOPort InMux 0 Addr1 (Out)
0 24 IOPort InMux 0 Addr2 (Out)
0 25 IOPort InMux 0 Addr3 (Out)
0 26 IOPort InMux 0 Addr4 (Out)
IO Connections for Outputs+P1
0 27 IOPort InMux 0 Data0 (In)
0 28 IOPort SSR 0 Out-00 (Out)
0 29 IOPort SSR 0 Out-01 (Out)
0 30 IOPort SSR 0 Out-02 (Out)
0 31 IOPort SSR 0 Out-03 (Out)
0 32 IOPort SSR 0 Out-04 (Out)
0 33 IOPort SSR 0 Out-05 (Out)
0 34 IOPort SSR 0 Out-06 (Out)
0 35 IOPort SSR 0 Out-07 (Out)
0 36 IOPort SSR 0 AC Ref (Out)
0 37 IOPort PWM 1 PWM (Out)
0 38 IOPort QCount 1 Quad-A (In)
0 39 IOPort QCount 1 Quad-B (In)
0 40 IOPort QCount 1 Quad-IDX (In)
0 41 IOPort None
0 42 IOPort None
0 43 IOPort SSerial 0 RXData2 (In)
0 44 IOPort SSerial 0 TXData2 (Out)
0 45 IOPort SSerial 0 RXData1 (In)
0 46 IOPort SSerial 0 TXData1 (Out)
0 47 IOPort None
0 48 IOPort QCount 2 Quad-A (In)
0 49 IOPort QCount 2 Quad-B (In)
0 50 IOPort QCount 2 Quad-IDX (In)
0 51 IOPort QCount 3 Quad-A (In)
0 52 IOPort QCount 3 Quad-B (In)
0 53 IOPort QCount 3 Quad-IDX (In)
Last edit: 4 years 9 months ago by Boaschti.
- Thank you received: 5334
4 years 9 months ago - 4 years 9 months ago #232488
Replied by PCW on topic Create a FPGA board for raspberry
A custom bitfile needs at least
The FPGA pinout (which pin goes to which GPIO bit/interface bit etc)
The I/O pinout (Which GPIO bit has which secondary function)
Note that you probably don't want to to use SSR modules unless you are using transformer isolation
Last edit: 4 years 9 months ago by PCW.
- Boaschti
- Topic Author
4 years 9 months ago #232501
by Boaschti
I want to use the fpga pinout from the 7c80.
What i have to use instead of ssr funktionality? I need simple outputs for air, water, vacuum, ligths, spindle (kress/amb).
What is the exactly funktionality of IO19...PWM.../ENABLE? Is it used to controll enable input of steppers/servos or is it used to disable pwmoutputs?
- D.L.
- Thank you received: 37
4 years 9 months ago #232513
by D.L.
Replied by D.L. on topic Create a FPGA board for raspberry
No sense to use multiplexers for expand inputs, xc6slx9 in spi hostmot2 configuration support up to 85 gpio pins(for example: 4 port x 21 pin or 5 port x 17 pin).
- Boaschti
- Topic Author
4 years 9 months ago - 4 years 9 months ago #232545
by Boaschti
Ok. Thats a interesting info.
My idea was to design the hardware very similar to the 7c80 board (IO0..IO36). There is already a bitfile for this and as a linuxcnc beginner I have fewer sources of error. So I can start more easy.
In future i want to have a bitfile for IO00..IO53. My machine doesn't has a encoder at this moment but it is planed.
But if I have to make a bitfile because of the ssr functionality then I can also remove the multiplexer.
- D.L.
4 years 9 months ago #232548
by D.L.
Before loading the firmware - all pins in high impedance state.
After loading the firmware - all pins in gpio mode.
After loading the LinuxCNC, pins may be switching to the secondary function - it defined in hal/ini config string.
If in config string defined num_ssrs=0, all ssr pins in gpio mode.
- Boaschti
- Topic Author
4 years 8 months ago #234691
by Boaschti
Time to create page: 0.090 seconds
