Raspberry Pi 4
- gtt38
- Thank you received: 4
09 Jan 2020 15:38 - 09 Jan 2020 15:38 #154451
by gtt38
I wanted to see the ability of a RPI4 to drive 2 FPGA at the same time :
But it's still not working on SPI1
I tried everything possible)
I've found a minimal FPGA board (the smallest i could find on chinese market)
4 layers and only 45x45mm with 3.3 and 1.2 voltage regulators at the back
Replied by gtt38 on topic Raspberry Pi 4
Really easy to create a custom board to protect I/O after..@ gtt38
m.aliexpress.com/item/4000141655235.html is the link to the FPGA board that worked for me.
I didn't see any protection for all the IO's on that board. It gets you lots of gates and unprotected IO, so you'll still need another board to get the IO's out to the real world in a machine environment.
Last edit: 09 Jan 2020 15:38 by gtt38.
The following user(s) said Thank You: Boaschti
- silden
- Thank you received: 3
09 Jan 2020 23:21 #154500
by silden
Replied by silden on topic Raspberry Pi 4
Hi All,
I got almost of all the issues resolved.
The Latency is reasonably low and the overall load too.
But I have occasional spikes in the read and write tmax of the 7c81.
The SPI clock is set to default and the core isn’t overclocked. The governor is set to performance and fore_turbo is activated. I plotted the clock and is reasonably stable around 500MHz.
I could trace some spikes to the graphics. It spikes when I move or resize a window.
The other spikes are random and couldn’t trace it.
Got anyone similar issues and how you resolved them?
Help is very appreciated.
Thank you,
Denis
Thank you,
Denis
- skunkworks
- Thank you received: 153
09 Jan 2020 23:26 #154501
by skunkworks
Replied by skunkworks on topic Raspberry Pi 4
Change from timesyncd to ntpd.
Aptget install ntp..
We have seen issues with the timesyncd.
The following user(s) said Thank You: silden
- silden
09 Jan 2020 23:30 #154502
by silden
I’ll try it.
Or should I install a RTC to turn off the fake hardware clock altogether?
- Thank you received: 5329
09 Jan 2020 23:31 #154503
Replied by PCW on topic Raspberry Pi 4
How bad is the latency?
(servo thread tmax is useful here)
- silden
09 Jan 2020 23:41 #154505
by silden
The servo-thread.tmax stays around 30-40% of the servo-thread cycle of 1ms.
But it jumps up to 60-89% during a occasional spike. while resizing a window, open a file or the one i couldn’t trace.
09 Jan 2020 23:43 #154506
Do you have isolcpus=3 in you kernel command line?
- skunkworks
09 Jan 2020 23:45 #154507
by skunkworks
I run 500hz servo thread..
- silden
09 Jan 2020 23:58 #154508
by silden
I have isolcpus=1,2,3.
- silden
10 Jan 2020 00:00 #154509
by silden
you mean .5 ms or 2ms servo-thread?
I’m not sure if a 2ms servo-thread will work with linear encoders on all axes.
Time to create page: 0.288 seconds
