After years of running, my first break down
14 Jan 2018 23:50 - 14 Jan 2018 23:51 #104483
Replied by PCW on topic After years of runni halcmd loadrt hm2_pci config="firmwang, my first break down
Unfortunately that does not help because again, the hm2_pci driver did not load
You are using such an old version of LinuxCNC that it may be there are bugs in halrun/halcmd
can you try this:
halrun
halcmd: loadrt hostmot2
halcmd: loadrt hm2_pci config="firmware=hm2/5i23/SVSS6_8.BIT"
halcmd: show all
if you get an error message after the loadrt hm2_pci line, there's no reason to proceed further
if you get no errors, copy and past the whole terminal session here (you will have to scroll back to get the whole listing)
since the show command will not be useful
can you try this:
halrun
halcmd: show all
Last edit: 14 Jan 2018 23:51 by PCW.
- schmidtmotorworks
- Thank you received: 6
15 Jan 2018 01:34 - 15 Jan 2018 01:36 #104485
by schmidtmotorworks
Replied by schmidtmotorworks on topic After years of runni halcmd loadrt hm2_pci config="firmwang, my first break down
parameter or pin 'halcmd' not found.
If I understand correctly, I will need to update my LINUX version and LINUXCNC version to make any progress.
Thanks a lot for all your efforts, I could not have figured this out on my own.
One good thing about this is I think i will be able to get my tool changer working on the latest release as I was stalled by a bug.
One last question, do you think it is worth trying to swap out any boards?
If so, which would you choose first?
The 2 boards with a lot of wires (7I64 ?) will be very difficult to swap, the others are easy.
Last edit: 15 Jan 2018 01:36 by schmidtmotorworks.
15 Jan 2018 01:45 #104488
I think I didn't explain very well
when you run halrun in the foreground ( without the & ), it prints the halcmd: prompt
so you just type the "loadrt" etc commands not halcmd
- schmidtmotorworks
15 Jan 2018 02:36 #104489
OK, I got it now, seems obvious after it is explained.
Here is the text
Here is the text
- schmidtmotorworks
18 Jan 2018 05:21 #104656
Looking at the output (not knowing what I am looking for), the only thing that looks obvious is this:
5 bit RW FALSE hm2_5i23.0.io_error
I am wondering if the least effort thing to try would be replacing the 5i23?
18 Jan 2018 14:33 #104666
OK so how many 7I64s do you have?
The missing pin is:
hm2_5i23.0.7i64.0.0.digin.19.in (port 0 channel 0)
But the pin list shows 2 7I64s ( port 0 channels 1 and 2 ) from the pin list:
5 bit OUT FALSE hm2_5i23.0.7i64.0.1.digin.19.in
5 bit OUT FALSE hm2_5i23.0.7i64.0.2.digin.19.in
So either you have 3 7I64s and one has quit working for some reason, of you only have 2 and you have swapped serial cables around...
The missing pin is:
- schmidtmotorworks
18 Jan 2018 18:07 #104682
PCW, thanks for looking at my problem again.
I have 2 7i64s.
I have not disconnected any wires since I built it about 5 years ago.
When you say "missing pin" does that mean that the connection to it is lost, like a wire became disconnected or whatever it is connected to is failing?
Or something internal to the control system?
I have 2 7i64s.
18 Jan 2018 19:14 #104685
Well someone must have swapped RJ45 connectors at some point, that is your pin list shows that the
2 7I64s are connected to the 7I44s channels 1 and 2, but you hal file is accessing a 7I64 at 7I44 channel 0
( and since nothing is connected to channel 0 it fails )
You probably need to look carefully at your hal file to
1. Find out what 7I64 numbers are used
2. Make sure when you fix the connections that you do not swap 7I64s as this would likely cause havoc
- schmidtmotorworks
18 Jan 2018 20:35 - 18 Jan 2018 20:38 #104697
I am 100% sure those cables have never been disconnected, I am the only one working in the shop and the electric door has not been opened in at least a year before it stopped working.
No files on the system were edited for about a year too.
I will check all the connections to make sure nothing fell out.
Last edit: 18 Jan 2018 20:38 by schmidtmotorworks.
18 Jan 2018 20:55 #104701
Well thats pretty mysterious
Can you take a picture of the 7I44 with the cables as they are now?
Moderators: cncbasher
Time to create page: 0.179 seconds
