After years of running, my first break down
- schmidtmotorworks
- Thank you received: 6
14 Jan 2018 01:56 #104409
by schmidtmotorworks
Replied by schmidtmotorworks on topic After years of running, my first break down
OK I did that.
I attached the text as it was in the terminal (terminal.txt)
because there was some message that looked important.
an all.txt.
an all.txt.
The following user(s) said Thank You: PCW
14 Jan 2018 13:52 #104428
Replied by PCW on topic After years of running, my first break down
well this is weird:
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/hm2_pci.ko': -1 Unknown symbol in module
This indicates to me that something basic is broken in the PC/LinuxCNC installation
- schmidtmotorworks
14 Jan 2018 18:19 #104445
Thanks for all of your help.
I have a solid state drive, I have heard that sometimes they get corrupted.
I will try to reinstall my current version of Linux CNC.first (assuming it is still available)
I hope the old version is still available because I tried to update to a newer version of Linux and LINUX/CNC about a year ago and the upgrade involved more problems that I was able to handle.
I would like to upgrade though, maybe I will try to build up the courage to try again.
- schmidtmotorworks
14 Jan 2018 19:52 #104452
I have a back-up hard drive so I switched to that.
Same problem.
Same problem.
14 Jan 2018 20:18 #104453
which error?
the "unknown symbol in module" is very different from the missing 7I64 pin
- schmidtmotorworks
14 Jan 2018 21:24 #104463
The page that comes up when I tried to run LINUX CNC, I can run the other command and see what happens.
I was thinking that using the different hard drive would eliminate the linux and Linux CNC install.
14 Jan 2018 21:32 #104466
Yeah, it should eliminate any file corruption issues but not PC-hardware/5I23/7I44/7I64 issues
Its still not clear to me what the real problem is since both 7I64s were detected, maybe PC/5i23
- schmidtmotorworks
14 Jan 2018 21:46 #104468
I ran both sets of commands that you told me about.
The all.txt file is empty.
I included all of the files most recently created.
14 Jan 2018 22:02 #104473
Replied by PCW on topic After years of runni halcmd loadrt hm2_pci config="firmwang, my first break down
That looks like the
halcmd loadrt hm2_pci config="firmware=hm2/5i23/SVSS6_8.BIT sserial_port_0=00000000"
^^^^^^^ This has to be all one line ^^^^^^^
command did not work at all
- schmidtmotorworks
14 Jan 2018 23:41 #104482
Replied by schmidtmotorworks on topic After years of runni halcmd loadrt hm2_pci config="firmwang, my first break down
Sorry for the mistake and thanks for your patience.
Here is the correct all.txt file.
Moderators: cncbasher
Time to create page: 0.533 seconds
