Bridgeport Torq Cut 22 Retrofit
12 Jun 2020 19:59 #171304
by Michael
Replied by Michael on topic Bridgeport Torq Cut 22 Retrofit
Finally back to working on this project. Got Linux Mint 19 working, 7i92 to 7i77 to 7i84 all powered up. Tried to set up an initial configuration with nothing connected to the boards except power and Ethernet between the different cards and the computer. Got the ether net set up and pinged with no issues. I did have to move the 7i92 W6 jumper to the up position to establish communication. I got a successful ping. I left it there and changed the Ethernet address in pncconf to 10.10.10.10 and choose some basic settings that I would be using and completed the wizard. I did get a no hm2 files found at the beginning of pncconf. I was also unable to check the mesaflash:
mesaflash --device 7i92 --addr 10.10.10.10 --readhmid
I started LCNC and got the following message that i attached as a report. I followed the directions for the Mesa ethernet setup for 7i92, 7i96, 7i76E and other ethernet Mesa boards. and even tried Big Johns method here. However I was unable to edit the file as it was read only.
Any help would be appreciated at this point.
- Thank you received: 5944
12 Jun 2020 20:06 #171306
And use ONLY one of the above tutorials, never both.
Also paste the ping times and what does
ip a
say ?
Replied by tommylight on topic Bridgeport Torq Cut 22 Retrofit
Nothing attached.I started LCNC and got the following message that i attached as a report. I followed the directions for the Mesa ethernet setup for 7i92, 7i96, 7i76E and other ethernet Mesa boards. and even tried Big Johns method here. However I was unable to edit the file as it was read only.
ip a
say ?
12 Jun 2020 20:15 #171308
by Michael
Here is ip a:
bridgeport@LinuxCNC:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 70:85:c2:82:1c:40 brd ff:ff:ff:ff:ff:ff
inet 10.10.10.11/8 brd 10.255.255.255 scope global noprefixroute enp1s0
inet6 fe80::708a:5:9f8:4244/64 scope link noprefixroute
3: wlp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 28:c6:3f:d3:19:3b brd ff:ff:ff:ff:ff:ff
inet 192.168.0.23/24 brd 192.168.0.255 scope global dynamic noprefixroute wlp2s0
valid_lft 70867sec preferred_lft 70867sec
inet6 2601:645:300:77c0:c835:cda3:ccef:da5f/64 scope global temporary dynamic
valid_lft 345599sec preferred_lft 70637sec
inet6 2601:645:300:77c0:bda7:bd29:3b40:c3ec/64 scope global dynamic mngtmpaddr noprefixroute
valid_lft 345599sec preferred_lft 345599sec
inet6 fe80::7296:2e9a:4671:56f2/64 scope link noprefixroute
All of the pings are in the .16 ms range
Here is ip a:
12 Jun 2020 21:23 #171321
The address is wrong in the ini file, it is looking for 192.168.1.121
12 Jun 2020 21:33 #171324
by Michael
Still getting an error. I had changed the address again in the process of trying to do everything over. Here is the file with the issues.
Also noticed during the pcconf wizard that it would not allow me to change the encoders off of "mux encoder" not sure if thats right or not.
12 Jun 2020 21:56 #171326
What does
say ?
Now you have 6 encoders set, but only 1 is available, so we need to know what firmware is installed.
In the meantime, you can change the port that the 7i77 is connected to and try again.
say ?
12 Jun 2020 22:07 #171329
by Michael
:mesaflash: command not found"
Not sure what you mean by change the port the 7i77 is connected to. Its plugged directly into the 7i92, I dont have the cabling to use the other port on the 7i92.
12 Jun 2020 22:14 #171331
oh cr@p !
I have over 20 of them so i thought you might have at least 1. Moving on
try
sudo mesaflash --device 7i92 --addr 10.10.10.10 --readhmid
see if it works.
Might not be installed at all, so
github.com/LinuxCNC/mesaflash
and some issues you may encounter
forum.linuxcnc.org/38-general-linuxcnc-q...e-for-7i97-mesa-card
try
see if it works.
12 Jun 2020 22:24 #171334
by Michael
Same response with the sudo. I could be wrong but my understanding was the 7i92 came with some basic firmware for most of the cards pre-installed. If they didn't then that is definitely my problem.
03 Dec 2020 19:24 #190976
by Michael
After a very long summer work season I think things are calming down enough to get back to this project.
I was able to download mesaflash, install and verify the firmware to the 7i92. I got good results from mesaflash --device 7i92 --addr 10.10.10.10 --readhmid
I had an error saying I was missing the firmware from lib/firmware/hm2 so I extracted the 7i92.zip to that location and the error went way.
I know get this attached error on start up of Linuxcnc
Moderators: cncbasher
Time to create page: 0.170 seconds
