firmware for 7i97 mesa card
  • cliffordkoperski@gmail.com
  • New Member
  • New Member
21 Sep 2019 09:29 #145751 by cliffordkoperski@gmail.com
firmware for 7i97 mesa card was created by cliffordkoperski@gmail.com
I would like to know if there are any updates available so i can use 7i97 ethernet card.
as things stand right now I can ping 192.168.1.121 however, if I try "mesaflash --device 7i97 --readhmid" I get firmware not supported for device.
mesa seems to not have any support software for this card but is listed as linuxcnc supported board
21 Sep 2019 09:54 #145753 by PCW
Replied by PCW on topic firmware for 7i97 mesa card
The 7I97 has generic firmware installed, so will work as-is
I will make additional firmware files that support various daughter cards
but these are not done yet
You need the latest mesaflash to recognize the 7i97:
github.com/jethornton/mesaflash
Currently for full operation with linuxCNC you will need to build LinuxCNC from source
and incorporate some 7I97 specific patches
  • New Member
  • New Member
21 Sep 2019 17:44 #145795 by cliffordkoperski@gmail.com
Replied by cliffordkoperski@gmail.com on topic firmware for 7i97 mesa card
Thank you for quick response!
I cloned link you provided, however I am so new with linux I am not sure how to apply this download. gethub quickstart instructions are unclear to me beyond git clone.
the 7i97 is still coming up as unsupported in terminal even though there is mention to the 7i97 in the mesaflash files like anyio.c.
your patience would be appreiciated
21 Sep 2019 18:23 #145797 by PCW
Did you go through the Quickstart instructions including the
sudo make install
step?
  • New Member
  • New Member
21 Sep 2019 18:53 #145800 by cliffordkoperski@gmail.com
that is were i am stuck ,
lagun@1:~$ cd mesaflash
lagun@1:~/mesaflash$
where do Igo from here?
lagun@1:~/mesaflash$ sudo make install
make: *** No rule to make target 'install'. Stop.
21 Sep 2019 19:10 #145801 by PCW
did you run make first?
  • New Member
  • New Member
21 Sep 2019 19:27 #145803 by cliffordkoperski@gmail.com
ok progress made!
lagun@1:~/mesaflash$ cd mesaflash
lagun@1:~/mesaflash/mesaflash$ make
now make is acknowledged
lagun@1:~/mesaflash/mesaflash$ sudo make install
[sudo] password for lagun:
install --mode=0755 --owner root --group root --dir /bin
install --mode=0755 --owner root --group root mesaflash /bin
so then I try
lagun@1:~/mesaflash/mesaflash$ mesaflash --device 7i97 --readhmid
ERROR: Unsupported device 7I97
should i restart pc ?
21 Sep 2019 20:25 #145806 by PCW
Thats odd, I get
peter@dc7800:~/Downloads/mesaflash-3.4$ mesaflash --device 7i97 --readhmid
No 7I97 board found
(which makes sense since I dont have a 7I97 here)
rebooting should not make any difference
Sounds like you are still running an old version, what does
mesaflash --help
print?
  • New Member
  • New Member
21 Sep 2019 20:39 #145809 by cliffordkoperski@gmail.com
lagun@1:~/mesaflash/mesaflash$ mesaflash --help
Syntax:
mesaflash --device device_name [options]
mesaflash --device device_name [options] --write filename
mesaflash --device device_name [options] --verify filename
mesaflash --device device_name [options] --program filename
mesaflash --device device_name [options] --readhmid
mesaflash --device device_name [options] --reload | --reset
mesaflash --device device_name [options] --sserial
mesaflash --device device_name [options] --rpo address
mesaflash --device device_name [options] --wpo address=value
mesaflash --device device_name [options] --set ip=n.n.n.n
mesaflash --info file_name
mesaflash --help
Options:
--device select active device name. If no command is given it will detect board with given name and print info about it.
--addr <device_address>
select <device address> for looking for <device_name> (network C mask for ethernet boards, serial port for USB boards)
--addr_hi set the high register address for the EPP interface
--epp use EPP interface to connect to board, only for boards with multiple interfaces (7i43, 7i90, 7i64)
--usb use USB interface to connect to board, only for boards with multiple interfaces (7i43, 7i90, 7i64)
--spi use SPI interface to connect to board, only for boards with multiple interfaces (7i43, 7i90, 7i64)
--serial use serial interface to connect to board, only for boards with multiple interfaces (7i43, 7i90, 7i64)
--fallback use the fallback area of the EEPROM while executing commands
--recover access board using PCI bridge GPIO (currently only 6I25)
--xml format output from 'readhmid' command into XML
--verbose print detailed information while running commands
Commands:
--write writes a standard bitfile 'filename' configuration to the userarea of the EEPROM (IMPORTANT! 'filename' must be VALID FPGA configuration file)
--fix-boot-block If a write operation does not detect a valid boot block, write one
--no-auto-verify Don't automatically verify after writing
--verify verifies the EEPROM configuration against the bitfile 'filename'
--program writes a standard bitfile 'filename' configuration to the FPGA (IMPORTANT! 'filename' must be VALID FPGA configuration file)
--readhmid print hostmot2 configuration in PIN file format
--reload do full FPGA reload from flash (only ethernet and pci boards)
--reset do full firmware reset (only ethernet boards)
--sserial print full information about all sserial remote boards
--rpo read hostmot2 variable directly at 'address'
--wpo write hostmot2 variable directly at 'address' with 'value'
--set set board IP address in eeprom to n.n.n.n (only ethernet boards)
--info print info about configuration in 'file_name'
--help print this help message
21 Sep 2019 20:53 #145810 by PCW
Yep that is the old version
Not the version I get when i run the quickstart instructions at
(just redid this)
Time to create page: 0.403 seconds
