PCI-E Parallel Card Problem
18 Oct 2016 14:35 - 18 Oct 2016 14:36 #81788
Replied by PCW on topic PCI-E Parallel Card Problem
If the parallel card does not require any special setup to operate, there is no need for Linux to detect
the card type or assign a driver (LinuxCNC just needs to know the cards I/O base address to work)
If on the other hand, there is some non-standard setup that is needed, Linux itself must have a driver for the card
to do the proper card specific setup (If this is the case using a newer LinuxCNC distribution may help)
In any case I would try the 0xE800 and 0xEC00 addresses
Last edit: 18 Oct 2016 14:36 by PCW.
- ped2datakanji
18 Oct 2016 14:45 #81789
by ped2datakanji
It didn't work either ,
in 0xec00 it shows this error:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.0
Machine configuration directory is '/home/datakanji/linuxcnc/configs/RTBN12080'
Machine configuration file is 'RTBN12080.ini'
INIFILE=/home/datakanji/linuxcnc/configs/RTBN12080/RTBN12080.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Killing task linuxcncsvr, PID=3171
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/hal_parport.ko': -1 Device or resource busy
RTBN12080.hal:7: exit value: 1
RTBN12080.hal:7: insmod failed, returned -1
See the output of 'dmesg' for more information.
3171
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 5157.577584] I-pipe: Domain RTAI registered.
[ 5157.577589] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 5157.577591] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 5157.577614] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATPrint file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.5.0
TASK=milltask
HALUI=
DISPLAY=axis
Cleanup done
3171
[ 5157.577614] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 5157.577616] PIPELINE layers:
[ 5157.577618] fb8f5e20 9ac15d93 RTAI 200
[ 5157.577620] c085cb20 0 Linux 100
[ 5157.591935] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 5157.592058] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 5157.592062] RTAI[sched]: hard timer type/freq = APIC/12468720(Hz); default timing: periodic; linear timed lists.
[ 5157.592065] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2693200000 hz.
[ 5157.592067] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 5157.592130] RTAI[usi]: enabled.
[ 5157.617611] RTAI[math]: loaded.
[ 5157.665359] config string '0xec00 out '
[ 5157.666377] PARPORT: ERROR: request_region(0xec00) failed
[ 5157.892913] RTAI[math]: unloaded.
[ 5157.916876] SCHED releases registered named ALIEN RTGLBH
[ 5157.948271] RTAI[malloc]: unloaded.
[ 5158.048023] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 5158.049803] I-pipe: Domain RTAI unregistered.
[ 5158.049831] RTAI[hal]: unmounted.
And with 0xe800 it open but i can't move or do anything
Replied by ped2datakanji on topic PCI-E Parallel Card Problem
OK, looks like 0xE800 or 0xEC00 are good addresses to try
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.5.0
TASK=milltask
HALUI=
DISPLAY=axis
Cleanup done
3171
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.5.0
TASK=milltask
HALUI=
DISPLAY=axis
Cleanup done
3171
- Thank you received: 1369
18 Oct 2016 14:45 #81791
Replied by Todd Zuercher on topic PCI-E Parallel Card Problem
Looks like e800 and ec00 might be addresses to try.
Does this section disapear from the lspci -v if you pull out the card?
02:00.0 Serial controller: Device 1c00:3250 (rev 10) (prog-if 05)
Subsystem: Device 1c00:3250
Flags: fast devsel, IRQ 17
I/O ports at e800
Memory at fdff8000 (32-bit, prefetchable) [size=32K]
I/O ports at ec00
Expansion ROM at feaf0000 [disabled] [size=32K]
Capabilities: <access denied>
18 Oct 2016 14:48 #81792
Looks like you have some empty PCI slots maybe try a PCI card instead of the PCIe.
- Thank you received: 5928
18 Oct 2016 16:23 #81798
Replied by tommylight on topic PCI-E Parallel Card Problem
Please use "sudo lspci -v" so you do not get access denied.
As it has been pointed out several times, it should be the addresses mentioned above, although it it has 1 paraport and 2 serial, I would expect 5 addresses, not 2.
Another issue while testing the paraport, when inserting an invalid address, you have to restart the computer before testing another address, since it will remain busy until restart.
- ped2datakanji
18 Oct 2016 16:42 #81799
by ped2datakanji
i tried and same thing, e800 doesn't move the CNC and the other (ec00 gives me an error):
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.5.0
TASK=milltask
HALUI=
DISPLAY=axis
Killing task linuxcncsvr, PID=1891
Cleanup done
1891
[ 179.709304] I-pipe: Domain RTAI registered.
[ 179.709309] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 179.709310] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 179.709334] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 179.709335] PIPELINE layers:
[ 179.709337] fd8e7e20 9ac15d93 RTAI 200
[ 179.709339] c085cb20 0 Linux 100
[ 179.723700] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 179.723847] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 179.723851] RTAI[sched]: hard timer type/freq = APIC/12468720(Hz); default timing: periodic; linear timed lists.
[ 179.723854] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2693183000 hz.
[ 179.723856] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 179.723919] RTAI[usi]: enabled.
[ 179.751161] RTAI[math]: loaded.
[ 179.799790] config string 'ec00 out '
[ 179.801182] PARPORT: ERROR: request_region(0xec00) failed
[ 180.031044] RTAI[math]: unloaded.
[ 180.054748] SCHED releases registered named ALIEN RTGLBH
[ 180.084357] RTAI[malloc]: unloaded.
[ 180.184018] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 180.185918] I-pipe: Domain RTAI unregistered.
[ 180.185947] RTAI[hal]: unmounted.
Does this section disapear from the lspci -v if you pull out the card?02:00.0 Serial controller: Device 1c00:3250 (rev 10) (prog-if 05) Subsystem: Device 1c00:3250 Flags: fast devsel, IRQ 17 I/O ports at e800 Memory at fdff8000 (32-bit, prefetchable) [size=32K] I/O ports at ec00 Expansion ROM at feaf0000 [disabled] [size=32K] Capabilities: <access denied>
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.5.0
TASK=milltask
HALUI=
DISPLAY=axis
Cleanup done
1891
- ped2datakanji
18 Oct 2016 16:43 #81800
by ped2datakanji
And if i remove the card i get this:
datakanji@datakanji-desktop:~$ sudo lspci -v
[sudo] password for datakanji:
00:00.0 Host bridge: Intel Corporation 4 Series Chipset DRAM Controller (rev 03)
Subsystem: Dell Device 043e
Flags: bus master, fast devsel, latency 0
Capabilities: [e0] Vendor Specific Information <?>
Kernel driver in use: agpgart-intel
Kernel modules: intel-agp
00:02.0 VGA compatible controller: Intel Corporation 4 Series Chipset Integrated Graphics Controller (rev 03)
Flags: bus master, fast devsel, latency 0, IRQ 26
Memory at fe400000 (64-bit, non-prefetchable) [size=4M]
Memory at d0000000 (64-bit, prefetchable) [size=256M]
I/O ports at ec00
Capabilities: [90] Message Signalled Interrupts: Mask- 64bit- Queue=0/0 Enable+
Capabilities: [d0] Power Management version 2
Capabilities: [a4] PCIe advanced features <?>
Kernel driver in use: i915
Kernel modules: i915
00:1b.0 Audio device: Intel Corporation N10/ICH 7 Family High Definition Audio Controller (rev 01)
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at feaf8000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [50] Power Management version 2
Capabilities: [60] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable-
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [100] Virtual Channel <?>
Capabilities: [130] Root Complex Link <?>
Kernel driver in use: HDA Intel
Kernel modules: snd-hda-intel
00:1c.0 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 1 (rev 01)
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00001000-00001fff
Memory behind bridge: c0000000-c01fffff
Prefetchable memory behind bridge: 00000000c0200000-00000000c03fffff
Capabilities: [40] Express Root Port (Slot+), MSI 00
Capabilities: [80] Message Signalled Interrupts: Mask- 64bit- Queue=0/0 Enable+
Capabilities: [90] Subsystem: Dell Device 043e
Capabilities: [a0] Power Management version 2
Capabilities: [180] Root Complex Link <?>
Kernel driver in use: pcieport
Kernel modules: shpchp
00:1c.2 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 3 (rev 01)
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00002000-00002fff
Memory behind bridge: feb00000-febfffff
Prefetchable memory behind bridge: 00000000c0400000-00000000c05fffff
00:1d.0 USB Controller: Intel Corporation N10/ICH7 Family USB UHCI Controller #1 (rev 01)
Flags: bus master, medium devsel, latency 0, IRQ 23
I/O ports at e880
Kernel driver in use: uhci_hcd
00:1d.1 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #2 (rev 01)
Flags: bus master, medium devsel, latency 0, IRQ 19
I/O ports at e800
00:1d.2 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #3 (rev 01)
Flags: bus master, medium devsel, latency 0, IRQ 18
I/O ports at e480
00:1d.3 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #4 (rev 01)
Flags: bus master, medium devsel, latency 0, IRQ 16
I/O ports at e400
00:1d.7 USB Controller: Intel Corporation N10/ICH 7 Family USB2 EHCI Controller (rev 01) (prog-if 20)
Memory at feaf7c00 (32-bit, non-prefetchable) [size=1K]
Capabilities: [58] Debug port: BAR=1 offset=00a0
Kernel driver in use: ehci_hcd
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1) (prog-if 01)
Bus: primary=00, secondary=03, subordinate=03, sec-latency=32
Capabilities: [50] Subsystem: Dell Device 043e
00:1f.0 ISA bridge: Intel Corporation 82801GB/GR (ICH7 Family) LPC Interface Bridge (rev 01)
Kernel modules: iTCO_wdt, intel-rng
00:1f.2 IDE interface: Intel Corporation N10/ICH7 Family SATA IDE Controller (rev 01) (prog-if 8f [Master SecP SecO PriP PriO])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 19
I/O ports at e080
I/O ports at e000
I/O ports at dc00
I/O ports at d880
I/O ports at d800
Capabilities: [70] Power Management version 2
Kernel driver in use: ata_piix
00:1f.3 SMBus: Intel Corporation N10/ICH 7 Family SMBus Controller (rev 01)
Flags: medium devsel, IRQ 5
I/O ports at 0400
Kernel modules: i2c-i801
02:00.0 Ethernet controller: Broadcom Corporation NetLink BCM57788 Gigabit Ethernet PCIe (rev 01)
Subsystem: Dell Device 0438
Flags: bus master, fast devsel, latency 0, IRQ 27
Memory at febf0000 (64-bit, non-prefetchable) [size=64K]
Capabilities: [48] Power Management version 3
Capabilities: [60] Vendor Specific Information <?>
Capabilities: [50] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable+
Capabilities: [cc] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting <?>
Capabilities: [13c] Virtual Channel <?>
Capabilities: [160] Device Serial Number 3a-a6-06-fe-ff-db-ba-a4
Capabilities: [16c] Power Budgeting <?>
Kernel driver in use: tg3
Kernel modules: tg3
I/O ports at ec00
I/O ports at e880
I/O ports at e800
I/O ports at e480
I/O ports at e400
I/O ports at e080
I/O ports at e000
I/O ports at dc00
I/O ports at d880
I/O ports at d800
I/O ports at 0400
Kernel modules: tg3
- ped2datakanji
18 Oct 2016 16:44 - 18 Oct 2016 16:47 #81801
by ped2datakanji
Oh, got it, thanks,
now i'm restarting the computer every address that i'm testing, and here's what appears:
I/O ports at dc00
Memory at fe9f8000 (64-bit, non-prefetchable) [size=16K]
00:1c.1 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 2 (rev 01)
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: fea00000-feafffff
Prefetchable memory behind bridge: 00000000fdf00000-00000000fdffffff
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O ports at d880
I/O ports at d800
I/O ports at d480
I/O ports at d400
Memory at fe9f7c00 (32-bit, non-prefetchable) [size=1K]
Bus: primary=00, secondary=04, subordinate=04, sec-latency=32
I/O ports at d080
I/O ports at d000
I/O ports at cc00
I/O ports at c880
I/O ports at c800
Flags: medium devsel, IRQ 15
I/O ports at 0400
I/O ports at e800
I/O ports at ec00
Capabilities: [60] Power Management version 3
Capabilities: [68] Message Signalled Interrupts: Mask+ 64bit+ Queue=0/5 Enable-
Capabilities: [80] Express Legacy Endpoint, MSI 00
03:00.0 Ethernet controller: Broadcom Corporation NetLink BCM57788 Gigabit Ethernet PCIe (rev 01)
Flags: bus master, fast devsel, latency 0, IRQ 28
Kernel modules: tg3
Oh, got it, thanks,
I/O ports at dc00
I/O ports at d880
I/O ports at d800
I/O ports at d480
I/O ports at d400
I/O ports at d080
I/O ports at d000
I/O ports at cc00
I/O ports at c880
I/O ports at c800
I/O ports at 0400
I/O ports at e800
I/O ports at ec00
Kernel modules: tg3
Last edit: 18 Oct 2016 16:47 by ped2datakanji.
18 Oct 2016 19:32 #81806
It looks like this would be pertinent to your problem.
ubuntuforums.org/archive/index.php/t-1629616.html
It also might just work if you used Wheezy instead of Lucid.
19 Oct 2016 00:49 #81816
There is also the possibility of it being a software emulated port, and that as far as i know will not do for Linuxcnc. This conclusion is due to you mentioning it has 2 serial and 1 parallel port, but since it shows only 2 addresses, i am wary.
Time to create page: 0.592 seconds
