Connect relays to 7i76
11 Aug 2017 11:21 #97332
by timmert
Replied by timmert on topic Connect relays to 7i76
11 Aug 2017 11:27 #97334
Replied by rodw on topic Connect relays to 7i76
No. only 1 diode per relay. Bengt has shown you how to do it on the bottom of page 1. Very clear.
11 Aug 2017 12:09 #97335
by timmert
11 Aug 2017 12:26 #97336
by bevins
Replied by bevins on topic Connect relays to 7i76
The wire on the side of the diode with the stripe goes to the 7i77 output pin. The side you have labled GND goes to field power COM.
The the two wires on the right where you have mistakenly labeled +24V is your contacts that will do whatever you want this output to do.
11 Aug 2017 12:38 #97337
Where does this go = +24v
GND = -24v
So the diode goes between these.
GND = -24v
11 Aug 2017 13:00 #97339
by bevins
The following user(s) said Thank You: andypugh
11 Aug 2017 13:05 #97340
by timmert
Thanks all, I got the cooling pump working!
Time to create page: 0.431 seconds
