- General
- General LinuxCNC Questions
- Debian install DVD ISO images not working due to CD-ROM bug in installer
08 Nov 2020 23:14 #188707
by Paedy
Replied by Paedy on topic Debian install DVD ISO images not working due to CD-ROM bug in installer
Thanks, too!
I had the same issue and solved it by using another USB port.
First it was on the back side and then it was on the top - works fine.
13 Dec 2020 16:08 #191871
by mwinterm
Replied by mwinterm on topic Debian install DVD ISO images not working due to CD-ROM bug in installer
...still have the same problem, but I'm using an SD-card as a reader and don't have a second SD-card slot...
Any advise?
Any advise?
13 Dec 2020 16:47 #191873
by pdxalz
Replied by pdxalz on topic Debian install DVD ISO images not working due to CD-ROM bug in installer
When you get the cd-rom message, try ejecting the card and reinserting it. That worked for me with a usb drive.
Also, the source of my problem was the options I chose when using the Rufus program to create the bootable drive. Selecting the dd method instead of the recommended iso method worked without problems.
Here is another link discussing this same issue: Not possible to install LinuxCNC 2.8 from USB stick?
- froglemort@harbaskin.com
10 Jan 2021 01:34 #194668
by froglemort@harbaskin.com
Replied by froglemort@harbaskin.com on topic Debian install DVD ISO images not working due to CD-ROM bug in installer
Thanks - Had the same issue where I could not get past the "Insert CDROM" prompting with a USB boot and I don't have a DVD/CDROM.
Swapping the boot USB stick into another USB port when prompted for the DVD/CDROM worked well.
- General
