Installing on Ubuntu 21.04
- pdxalz
- Thank you received: 3
26 Nov 2020 04:47 #190316
by pdxalz
Replied by pdxalz on topic Not possible to install LinuxCNC 2.8 from USB stick?
I have a very similar system, except it is the Gigabyte GA-D525STUD and I only have 2G of RAM. I'm also using the onboard graphics adapter. I had the same install problem you described when I tried to install Buster, but I got past the error:
At the "Detect and mount CD-ROM screen ... couldn't be mounted" screen, I pull the USB drive out and then reinsert it. Then I hit continue and the install goes fine after that.
Also, I tried the RTAI kernel for the Buster install but the system didn't seem to work as well as it did with Wheezy. I ended up buying a cheap ASRock J3355B (also ITX, but with a Celeron). It also has the USB install problem and the same fix works. I haven't been able to get the Buster RTAI to work on it yet, but it works great with Wheezy. It was discussed on this thread: forum.linuxcnc.org/38-general-linuxcnc-q...tency-mesage?start=0
- BeagleBrainz
- Visitor
26 Nov 2020 08:45 #190320
by BeagleBrainz
I've used the exact same ASRock board and never had any issues with installation via USB. Did you try other USB sticks or did you only try the one ?
Replied by BeagleBrainz on topic Not possible to install LinuxCNC 2.8 from USB stick?
- pdxalz
26 Nov 2020 22:48 #190380
by pdxalz
Buster installs fine now on both motherboards, D525 and J3355. (I'm not the original poster) The problem in my case appears to be how I created the bootable usb drive. Before, I created the bootable drive from my Windows PC using the Rufus program. It created a usable drive, but required unplugging and reinserting the usb drive.
When I used Buster to create the drive using "dd" it worked fine.
Also verision 3.11 of Rufus on Windows worked fine if I selected the "Write in DD mode" instead of the recommended "write in ISO image mode", after hitting the start button.
- Dave H
06 Dec 2020 01:40 #191196
by Dave H
Replied by Dave H on topic Not possible to install LinuxCNC 2.8 from USB stick?
Well, I finally got this to work with The 2.8 iso and Buster. Removing the usb stick and resetting the BIOS to default values seemed to do the trick. I used Rufus to create the usb in iso mode.
Thanks to all for the help!!
- Benb
- Thank you received: 61
06 Dec 2020 23:31 #191280
by Benb
Replied by Benb on topic Not possible to install LinuxCNC 2.8 from USB stick?
I second that, I used RUFUS 3.13 to install LinuxCNC 2.8.0 it worked well for an HP elitedesk 800 g1 (i5 8meg ram). Jitter around 42000ns using pre-emptrt.
- Adam Maszynotwór
- Thank you received: 12
19 Dec 2020 07:03 #192430
by Adam Maszynotwór
Replied by Adam Maszynotwór on topic Not possible to install LinuxCNC 2.8 from USB stick?
I confirm the existence of the problem - Same problem with Lenovo 6072-CTO computer - (cannot see CD / DVD)
Pendrive made in LinuxLive USB Creator (LiLi) (I've always done this and old versions worked)
Only making the Pendriwa in Rufus 3.13 helped
- GlasairMan
01 Jul 2021 12:55 #213429
by GlasairMan
Replied by GlasairMan on topic Not possible to install LinuxCNC 2.8 from USB stick?
Rufus is a Wiondows program and (as it warns you) may not contain all the files you need for a Linux install - as I found out. If you already have a Linux system, use the USB Media Creator which is part of most Distis (I have Ubuntu)
as
But don't ask me why they package it a pretty outdated Debian .iso
It would have been much better as a Ubuntu Linux Snap in the Store
as
- GlasairMan
01 Jul 2021 12:58 #213430
by GlasairMan
..and who uses DVD drives today? I plopped a SSD in a Caddy in there YEARS ago. Get up to date, guys!!
- Thank you received: 7466
01 Jul 2021 15:40 #213438
Replied by tommylight on topic Not possible to install LinuxCNC 2.8 from USB stick?
forum.linuxcnc.org/9-installing-linuxcnc...-nearly-easy-install
Current enough?
Current enough?
- GlasairMan
01 Jul 2021 23:15 #213462
by GlasairMan
.iso 2.8 Buster downloaded today if thats what you mean.
if you mean Rufus, also latest version
Time to create page: 0.274 seconds
