Installing on Ubuntu 21.04
- Thank you received: 7466
01 Jul 2021 23:25 #213463
Replied by tommylight on topic Not possible to install LinuxCNC 2.8 from USB stick?
From reports here Rufus is "hit and miss", better to use win32diskimager on windows or DD on Linux.
I meant is Mint 20 (or Ubuntu 20 as that also works for it) current enough?
Personally i use Mint 19.3, install info on "installing LinuxCNC" section of the forum.
- GlasairMan
02 Jul 2021 07:35 #213480
by GlasairMan
Replied by GlasairMan on topic Not possible to install LinuxCNC 2.8 from USB stick?
Hi thanks for your answer.
My comment on "obsolete" - I was referring to xfce which is is aimed at maybe a community to which I do not belong, namely Windows Users who have a Raspberry or 10 year old laptop lying around and are strangers to Linux. That's the only reason I can think of to package it as an "all-in-one" ISO with the LinuxCNC app preinstalled-. I on the other hand am a power user of Linux since 2004 and would have preferred a repository that I could add in to my existing Ubuntu Buster system
02 Jul 2021 08:55 #213482
Buildbot.linuxcnc.org
- Thank you received: 4648
03 Jul 2021 22:36 - 03 Jul 2021 22:37 #213607
We used to package with Ubuntu, then Ubuntu changed the rules and demanded that all Ubuntu branding was removed from any derivative distributions. This was more work than we could support (and how can you be sure you found it all?) so we switched to Debian.
If you are a Linux Power User then you can run LinuxCNC on the distro of your choice. The ISO is to make it easier for those new to Linux. Asking _them_ to patch and build a kernel, satisfy dependencies and then build from source seems a bit much.
Replied by andypugh on topic Not possible to install LinuxCNC 2.8 from USB stick?
Last edit: 03 Jul 2021 22:37 by andypugh.
03 Jul 2021 23:06 #213616
Reading this again, just noticed something wrong, there is no Ubuntu Buster.I on the other hand am a power user of Linux since 2004 and would have preferred a repository that I could add in to my existing Ubuntu Buster system
- GlasairMan
04 Jul 2021 11:47 #213660
by GlasairMan
Replied by GlasairMan on topic Installing on Ubuntu 21.04
you are right , it's hirsute (was confusing with my raspberry where there IS a Buster)
I tried to install the ppa keyring
sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key 3cb9fd148f374fef
but it was rejected as apt-key now deprecated
Using wget , it says no valid gpg key found
gpg: Keine gültigen OpenPGP-Daten gefunden.
Any ideas ???
Any ideas ???
- GlasairMan
04 Jul 2021 12:16 #213665
by GlasairMan
using the new procedure replacing apt-key.......Ubuntu 21.04 now requires a valid port number to linuxcnc.org repository in order to automatically get the key. So knowing that the key is 3cb9fd148f374fef doesn't help me at all
Looks like Ubuntu has tightened security over Debian which uses the old ppa method apt-key method
- phillc54
- Thank you received: 2100
04 Jul 2021 12:35 #213672
by phillc54
www.linuxuprising.com/2021/01/apt-key-is...ated-how-to-add.html
Replied by phillc54 on topic Installing on Ubuntu 21.04
Not according to this:Looks like Ubuntu has tightened security over Debian which uses the old ppa method apt-key method
04 Jul 2021 15:28 #213699
There are 3 more keyservers there thanks to PhillC.
Replied by tommylight on topic Installing on Ubuntu 21.04
forum.linuxcnc.org/9-installing-linuxcnc...nd-easy-installationI tried to install the ppa keyring
