Installing on Ubuntu 21.04
5 years 11 months ago #189941 by Dave H
I have created a USB stick with the 2.8 installation files on it from the ISO. I can run 2.8 live from the stick just fine. If I try either the Install or Graphic Install option, when I get to the section for identifying a CD-ROM drive the installation has to be aborted. I do not have a CD drive in the system. I have tried a USB CD-ROM drive with a DVD in it with the installation files on it, but it is not recognized by the system.
UEFI is disabled. BIOS set to boot from USB first. I have created DVDs from both Rufus and the Windows ISO burner app.
Is is not possible to install from the USB stick?
5 years 11 months ago #189944 by rootboy
I had no problems installing it on two different PCs. However, each one does have a CD/DVD drive.
I don't recall having to specify a CD/DVD drive, probably because one was already installed on my systems.
I suppose that you could borrow or buy a USB CD/DVD drive. They go for about $25 on Amazon.
5 years 11 months ago #189945 by Dave H
I did attach a USB CD/DVD burner to the system and it was not recognized.
5 years 11 months ago #189955 by rootboy
I have an old Dell 755 here and I am in the process of downloading Ubuntu 32 bit for it. I had some issues with the old beast, no HDD, but I found one, and the memory had to be reseated to get it to boot.
I had tried LXLE but it wouldn't boot. We'll see what Ubuntu Mate does...
Back to your problem, Does your PC see the CD/DVD in BIOS? And what version of Linux are you trying to install? Try installing a different version.
Meanwhile I will try to get Ubuntu going on my beater box PC.
5 years 11 months ago #189957 by rodw
Win32diskimager is your friend for bootable USB from Windows. Try using that.
5 years 11 months ago #189988 by rootboy
So no surprises here, Linux installed without needing the CD/DVD drive to be connected.
Time to create page: 0.180 seconds
