pdxalz wrote: I have a very similar system, except it is the Gigabyte GA-D525STUD and I only have 2G of RAM. I'm also using the onboard graphics adapter. I had the same install problem you described when I tried to install Buster, but I got past the error:
At the "Detect and mount CD-ROM screen ... couldn't be mounted" screen, I pull the USB drive out and then reinsert it. Then I hit continue and the install goes fine after that.
Also, I tried the RTAI kernel for the Buster install but the system didn't seem to work as well as it did with Wheezy. I ended up buying a cheap ASRock J3355B (also ITX, but with a Celeron). It also has the USB install problem and the same fix works. I haven't been able to get the Buster RTAI to work on it yet, but it works great with Wheezy. It was discussed on this thread: forum.linuxcnc.org/38-general-linuxcnc-q...tency-mesage?start=0
