Tandem y axis for plasma table
- Electechcans
06 Oct 2020 19:29 #185122
by Electechcans
Replied by Electechcans on topic Tandem y axis for plasma table
I unchecked the box in pncconf and resaved and it went away, so i changed it to what you said with direction instead of step and it still does the same thing.
06 Oct 2020 19:32 #185123
Replied by rodw on topic Tandem y axis for plasma table
You cannot have a -2 for home sequence without a -1 as well. I answered your question elsewhere
The following user(s) said Thank You: dvn4life1972
06 Oct 2020 19:41 #185126
Replied by PCW on topic Tandem y axis for plasma table
Yes there's a bug in pncconf where it swaps the invert step/dir function
(if you tell it to invert direction it inverts step,if you tell it to invert step it inverts direction)
- Electechcans
06 Oct 2020 19:54 #185127
by Electechcans
I changed the home sequence for joint 0 to -1 so it isn't 1 and it acts the same.
06 Oct 2020 19:56 #185129
Did you fix the inverted step signal?
- Electechcans
06 Oct 2020 19:58 #185130
by Electechcans
Yes i fixed this
- Electechcans
06 Oct 2020 20:03 #185131
by Electechcans
In the hal file the Halui signals only shows 3 joints 0,1,2, does this have something to do with it.
06 Oct 2020 20:03 #185132
OK, to get a better idea of what's going on
can you see if the commanded joint 2 position (joint.2.motor-pos-cmd)
moves when you start homing? (you can disconnect the drives)
for this test.
for this test.
- Electechcans
06 Oct 2020 20:12 #185134
by Electechcans
Replied by Electechcans on topic 4 axis plasma with Mesa 7i96
I tried changing both y joints to -1, just joint 1 just joint 2 and the same thing. Every combo still does the exact same thing. Y2 just runs away in the program but doesn't actually output to the drive.
- Electechcans
06 Oct 2020 20:13 #185135
by Electechcans
It definitely does it just runs away but no output to the drive. All the other joints home and joint 2 position just keeps counting.
Time to create page: 0.480 seconds
