Tandem y axis for plasma table
1. Are the step timings still at 5000,5000,20000,20000? (they should be)
2. How is the 7I96 wired to the drive? (some drives need single ended wiring)
I tried changing both y joints to -1, just joint 1 just joint 2 and the same thing. Every combo still does the exact same thing. Y2 just runs away in the program but doesn't actually output to the drive.
It makes no difference be it -1 or -2 as long as both Y joint have the same - number.
I do notice that your step timings in the ini file are very short ie. 1000 try them at 4000
also the min and max limits should be the same in the axes part as well as the joint. You only have them is the axes section.
Yes you do need to home before you can jog the Y axis.
Edit : I notice that you are asking the same questions on two separate post !!!!
When you fire up the axis gui you should see the 4 joints on the screen then when homed it should change to just show the 3 axis XYZ
You cannot have a -2 for home sequence without a -1 as well. I answered your question elsewhere
I am not sure you are correct with the above. as long as the number don't have a gap they should be fine.
You don't need a -1 before a -2 you can use 0,1,-2 or 1,-2,0
- Electechcans
I would adjust the scaling in LinuxCNC via the calibrate menu
- Electechcans
Okay so i messed around with this some more and both Y1 and Y2 are working in tandem with the sequence for both set at -2 but i had to swap around the wires for the direction because even with it showing to run inverted in the hal file it still runs the same direction. I dont see why but im okay with that as long as it runs, now im working on the scaling and if i try to increase my step timings to suggested settings 5000,5000,20000,20000 i get velocity errors coming up and it just writes over my values. I tuned my scaling in pncconf but now in linuxcnc it is way off. Should i tune for linuxcnc or pncconf? This is so damn frustrating. I can move every axis to home and limits but i am no where near the correct scaling for a 48 inch by 48 inch cutting area.
now you are this far I would not use pncconf as it will over write your files so use an editor to alter them.
you can either swap the wires over OR just put a - in front of the scale
.i get velocity errors coming up and it just writes over my values.
What is the actual error and what do you mean by "its just write over my value"?
- Thank you received: 5954
It can be -2, as long as both joint for a tandem axis have the save value.You cannot have a -2 for home sequence without a -1 as well. I answered your question elsewhere
- Electechcans
