fanuc encoder
18 Dec 2020 20:23 #192380
by chris@cnc
fanuc encoder was created by chris@cnc
Hi
in this moment i am playing with one old Fanuc serial encoder. But i can't found any useful example for config.
Only one here but not working.
forum.linuxcnc.org/10-advanced-configura...20-and-fanuc-encoder
I put this linein hal and try to find any connection pins. second big question. Do i have connect to encoder or sserial input? Could someone give me light in this yellow / black box.
I use a mesa 7i76e and this have one encoder and one sserial input.
Thanks Christian
I put this line
loadrt hm2_eth board_ip="10.10.10.2" config="fanuc_chan_0=AA64 num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=20xxxx"
Thanks Christian
18 Dec 2020 21:05 #192387
Replied by PCW on topic fanuc encoder
The Fanuc serial encoder uses a RS-422 interface so requires
a differential TX and RX pair, The serial expansion port on the
7I76E could be used for this but it would require custom firmware
18 Dec 2020 21:39 #192392
by chris@cnc
Replied by chris@cnc on topic fanuc encoder
Is this firmware free and How can i load into Mesa?
- Thank you received: 1370
18 Dec 2020 21:55 #192394
Replied by Todd Zuercher on topic fanuc encoder
Yes, the firmware for Mesa cards are opensource and free. But what I think he means by custom is that a firmware that supports it doesn't exist (yet) and will have to be created/configured for your specific hardware.
- Thank you received: 5945
18 Dec 2020 22:04 #192396
Replied by tommylight on topic fanuc encoder
The IP should be 10.10.10.10
18 Dec 2020 22:16 #192399
by chris@cnc
I change adress. This my Real Simulator. And Basic Connection is working.
Have someone example configuration ?
The IP should be 10.10.10.10[/quote][/code]
19 Dec 2020 00:02 #192412
freeby.mesanet.com/7i76e-fanuc.zip
Is standard 7i76e firmware with one FANUC encoder on
the serial expansion port.
The following user(s) said Thank You: chris@cnc
Time to create page: 0.311 seconds
