Trajectory Planner using Ruckig Lib
09 Nov 2023 10:41 #284931
by Grotius
Replied by Grotius on topic Trajectory Planner using Ruckig Lib
Thanks for testing.
Notice the pauses at various points.
Yes between the moves the pause could be less.
This can mean a few things :
- Somewhere a delay is given between 2 gcode segments, like Rodw is mentioning.
But i suspect that is not the case.
- Scurve software need a tiny end velocity between 2 paths, wich is currently not present in the planner.
Todo: check If the scope is not showing the delay between the moves.
S-Curve freezing
This "nan" message is clearly a tiny error and will stop your program and so on.
But is quite easy to solve in next github update.
As for my conclusion, it's not bad for Joco's first attempt.
I would see 4 things changing, like solving the snerping sound in Joco's machine,
remove pauses between moves, solve the nan error, solve the cmake installation.
Thanks for testing.
S-Curve freezing
09 Nov 2023 10:49 #284932
I wonder if its harmonics induced by jerk limited velocity or something loose?
Replied by rodw on topic Trajectory Planner using Ruckig Lib
I had to put headphones on to hear the snerping sound!solving the snerping sound in Joco's machine,
09 Nov 2023 11:28 #284936
by Grotius
@Joco,
When the isnan occured, i suspect you did a mdi move for a given arc?
Do you remember the given gcode that caused the isnan? Thanks.
09 Nov 2023 13:59 #284942
by tivoi
Replied by tivoi on topic Trajectory Planner using Ruckig Lib
thanks
sucess build after build orginal linuxcnc 2.10
i will try test with real machine then report
09 Nov 2023 16:44 #284950
by Grotius
I have seen the build problem on the virtual machine "vm", where it's running a debian 12.
It's related to halcompile. Halcompile isn't working properly somehow.
It's not finding the Makefile.modinc somehow. Even the rip-environment is done.
Is now solved by changing the build system procedure.
Good luck man. I hope you can "rock and roll a bit" with the scurve.
I am still lerking on a vm.
Github is just updated for changing the build system, also the isnan error is prevent freezing now.
More printf output when isnan occurs.
- compile lcnc the original way.
- overwrite build with cmake.
The following user(s) said Thank You: Joco
09 Nov 2023 17:31 #284952
by Joco
Replied by Joco on topic Trajectory Planner using Ruckig Lib
I will pull and run another test today.
Another quirk i was encountering was if i touched off in axis to shift the wcs 0,0 axis would not run the programme. In fact generally became unresponsive. Will see if can reproduce today and trap info from console. I’ll try grabbing that all to file for easier reference.
Cheers - J
Cheers - J
09 Nov 2023 17:34 #284953
by Joco
Or its the squeaky cable chain you guys are hearing. No idea what snerping even is and I’m in the same room as the thing.
09 Nov 2023 20:30 #284970
by Joco
Did some sim checks this morning as had noticed some off errors appeating. Two files attached:
1. is a clean Axis mm UI start, move the wcs x,y to a new location in machine space, stop. This on 2.9 linuxcnc
2. is the same process but on 2.10pre compiled from the repo.
Observation:
USRMOT error command 31 due to a timeout.
Tinker callback error which results in Axis becoming unresponsive. This happened after/on touching off Y axis to 0. I tested it the other order (y then x) and the error triggered on the X touch off. So it seems to be the second touchoff activation triggering things not what axis it is.
Not sure if these are tied to a more general issue with 2.10pre or with changes in this particular code line. I get the same problem under 2.10pre with either s-curve or standard tp's.
Cheers - James.
Observation:
Cheers - James.
09 Nov 2023 20:37 #284971
2.10 removes lube and a couple of other pins. check in the docs that what is in your cooling.hal still exist.
09 Nov 2023 21:06 #284973
by Joco
ccoling hal? What is that? Is that part of Sim?
Time to create page: 0.181 seconds
