rtai kernel installation on Debian 12.4 linuxcnc 2.9.2
- Thayloreing
18 Mar 2024 13:43 #296198
by Thayloreing
Good morning, I wanted to know how to install the rtai kernel on Debian 12 linuxcnc 2.9.2, I'm trying to do it according to the manual, but my latency got worse after I installed the rtai 5.4 kernel, my latency went to 200k, with preent rt 6.18 it was at 60k.I previously had Debian 10 with Linuxcnc 2.8.4 with Rtai 4.19 kernel, it worked perfectly on its 15k.However, I want to move on to the newest version, I'm still practically a beginner, so I apologize if it's something very simple. Could you tell me how to install the rtai kernel on linuxcnc 2.9.2 on Debian 12.4 step by step? I would really appreciate it
18 Mar 2024 15:28 #296212
by cornholio
Replied by cornholio on topic rtai kernel installation on Debian 12.4 linuxcnc 2.9.2
It sounds like you successfully installed the kernel.
After booting I check you are actually running the correct kernel.
uname -a will tell you what kernel you are running.
If it is incorrect usually when grub loads you should have the chance to select the advanced menu and choose your kernel from there.
- Thayloreing
18 Mar 2024 15:57 #296214
by Thayloreing
Replied by Thayloreing on topic rtai kernel installation on Debian 12.4 linuxcnc 2.9.2
hi, thank you very much for your answer, I checked the kernel using uname -a, I was running the rtai kernel, but the latency was through the roof anyway
18 Mar 2024 16:19 #296221
by cornholio
Sounds like something Andy is better off trying to sort out.
Got me stumped mate.
- Thayloreing
18 Mar 2024 18:57 #296240
by Thayloreing
I installed grub-customizer to isolate the cpu and change the boot kernel
- Thayloreing
18 Mar 2024 19:29 #296244
by Thayloreing
Could you tell me how do you install the rtai kernel? I believe I'm forgetting something
18 Mar 2024 21:01 #296251
by cornholio
You have installed it.
If you can boot the kernel it’s installed.
The issue is the latency is no good for whatever reason.
- Thank you received: 5967
18 Mar 2024 23:49 #296264
Replied by tommylight on topic rtai kernel installation on Debian 12.4 linuxcnc 2.9.2
uname -a
18 Mar 2024 23:57 #296266
by cornholio
The OP has confirmed he’s running an RTAI kernel. Tho the output of the command hasn’t been confirmed.
My first thought was that he had booted a vanilla kernel.
19 Mar 2024 00:04 #296269
OK
From experience, when you get worse latency with RTAI kernel, it usually means the motherboard is on the way out, be it from dry capacitors, memory/controller issues, processor to hot, hard drive failing and keeping IRQ busy, etc, so first check the PC for bulged capacitors.
Time to create page: 0.087 seconds
