rtai kernel installation on Debian 12.4 linuxcnc 2.9.2
- Thayloreing
19 Mar 2024 00:28 #296272
by Thayloreing
Replied by Thayloreing on topic rtai kernel installation on Debian 12.4 linuxcnc 2.9.2
hi good evening, thank you for the answer, I had Debian 10 installed before with kernel rtai 4.19 linuxcnc 2.8.4, it worked perfectly, in its 15k
- Thayloreing
19 Mar 2024 00:35 #296275
by Thayloreing
hi good evening, I downloaded the rtai kernel from the linuxcnc website in the download part of linuxcnc 2.9.2
19 Mar 2024 00:44 #296277
by cornholio
Replied by cornholio on topic rtai kernel installation on Debian 12.4 linuxcnc 2.9.2
You followed the instructions.
The RTAI was successfully installed.
You boot linuxcnc with the RTAI kernel.
The issue is for reasons unknown you are not getting good latency.
Instructions telling you how install the kernel will not fix the latency issue. No amount of installation instructions will fix this issue. None.
You keep asking for installation instructions, but that is the wrong question. Constantly asking this question will not remedy your latency issues. Please please try to understand this.
- Thayloreing
19 Mar 2024 00:57 #296279
by Thayloreing
I understand that, I just want to know how to solve the problem if it wasn't an installation error, I just want to try to solve the problem, because I wanted to use QT, that's why I left Linuxcnc 2.8.4, but I had this misfortune
Time to create page: 0.076 seconds
