Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
23 Aug 2017 12:49 #97922
Replied by andypugh on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
That depends on what the index-enable signal is called.
But maybe
sets index-enable true
But maybe
23 Aug 2017 12:50 #97924
by tecno
Replied by tecno on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
sets spindle-index-enable true = no error message
Then to look where and what?
23 Aug 2017 12:59 #97925
See if it stays true when you rotate the spindle.
23 Aug 2017 13:03 #97927
by tecno
Looking at signals = it is set to true and nothing happens when rotating the encoder. I have set this up here in my lab.
23 Aug 2017 13:12 - 23 Aug 2017 13:17 #97929
Replied by PCW on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
I would "sets" the index enable signal but watch the encoder index enable pin (since a incorrect hal file setup might not link these)
What should happen is this:
The encoder index-enable pin should be low initially
When you "sets" the index-enable signal, the encoder index-enable should go true
then when you rotate the encoder past the index position, the encoder index-enable pin
should go false
should go false
Last edit: 23 Aug 2017 13:17 by PCW.
23 Aug 2017 15:19 #97935
by tecno
So I´m back.
encoder-index-enable pin is low and stays low after sets spindle-index-enable true = no change
23 Aug 2017 16:05 #97938
OK so that means that the hal file is not correct (it does not "net" spindle-index-enable to the encoder index-enable pin)
23 Aug 2017 16:14 #97939
by tecno
23 Aug 2017 19:33 #97944
All the spindle encoder setup is missing from that hal file
If I run pncconf here I get the right setup/scaling and net connections
Is it possible you left out something like setting up encoder 0 as spindle encoder in pncconf?
23 Aug 2017 19:39 #97945
by tecno
Most likely, pncconf is not at all beginner friendly.
So what next and not messing up what is there. Run a new setup and copy paste ?
Time to create page: 0.236 seconds
