Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
03 Sep 2018 15:14 #117013
Replied by andypugh on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
You don't need those any more, I hard-coded the numbers
03 Sep 2018 15:36 #117014
by tecno
Replied by tecno on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
OK
Still I can not wrap my head around this as I am not a programmer.
So what needs to be done in hal?
04 Sep 2018 14:34 #117054
by Hakan
Replied by Hakan on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
Don't really want to interfere when Andy has got you on a good track.
But look in the "comp". There are several "pin in" at the top 15 lines. Connect them.
Make sure the comp is loadrt'd and addf'd in the hal file.
Then, being a bit defensive, start linuxcnc. Open halshow and watch the "pin out" signals
from the comp. Change gears and such things, and see if the output pins behave as you want.
04 Sep 2018 14:41 #117055
by tecno
Hi HÃ¥kan,
forum.linuxcnc.org/39-pncconf/33069-help...ing?start=590#116883
Already done, just need to go down and start LCNC and try
I was convinced that SETP was needed but obviously not.
Maybe I get a timeslice after dinner today to do a test you suggest.
04 Sep 2018 15:04 #117057
by Hakan
Naah, if you have the version from this post forum.linuxcnc.org/39-pncconf/33069-help...ing?start=590#116868, the setp's aren't needed, as Andy says the speeds are hard coded..
04 Sep 2018 18:16 #117068
I have been away for a few days. Where are you with this now?
04 Sep 2018 18:22 #117069
by tecno
Hi Andy,
Still in same spot have not tried anything, been a bit offline due to joint pains again and then I tend to go off-line so to speak.
Cheers
Cheers
05 Sep 2018 10:03 #117088
by tecno
Morning all,
Here my report from the shop, compiles OK and I get following error message.
Message string for index 0 missing
message: rtapi_app_main: Invalid argument (-22)
./GB_2speed.hal:18: waitpid failed /usr/bin/rtapi_app message
./GB_2speed.hal:18: /usr/bin/rtapi_app exited without becoming ready
./GB_2speed.hal:18: insmod for message failed, returned -1
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Note: Using POSIX realtime
LinuxCNC terminated with an error.
05 Sep 2018 10:25 #117090
It looks like you have not set the message comp up right. You need a message for each gear, telling the user how to set the controls.
05 Sep 2018 10:27 #117091
by tecno
OK
Give me a hint on how and where to do this and I will try to scribble something up.
Time to create page: 0.311 seconds
