Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
05 Sep 2018 14:08 #117104
by tecno
Replied by tecno on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
So this line is Ok
loadrt GB_2speed
and this should be
addf GB-2speed.0 servo-thread
loadrt GB_2speed
and this should be
05 Sep 2018 14:13 #117105
Replied by andypugh on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
I think so. The real answer is to try it and then read the error messages
05 Sep 2018 14:20 #117106
by tecno
Edit all GB_2 to GB-2
./GB_2speed.hal:160: setp requires 2 arguments, 3 given
setp motor-high-signal <= GB-2speed.0.motor-high
05 Sep 2018 14:24 #117107
That setp should be a net
05 Sep 2018 14:28 #117109
by tecno
Fixed
./GB_2speed.hal:170: Pin 'GB-2speed.0.message.1' does not exist
So we have errors probably on all lines below
net m1 GB-2speed.0.message.1 => gear1.trigger
net m2 GB-2speed.0.message.2 => gear2.trigger
net m3 GB-2speed.0.message.3 => gear3.trigger
net m4 GB-2speed.0.message.4 => gear4.trigger
net m5 GB-2speed.0.message.5 => gear5.trigger
net m6 GB-2speed.0.message.6 => gear6.trigger
net m7 GB-2speed.0.message.7 => gear7.trigger
net m8 GB-2speed.0.message.8 => gear8.trigger
net m9 GB-2speed.0.message.9 => gear9.trigger
net m10 GB-2speed.0.message.10 => gear10.trigger
net m11 GB-2speed.0.message.11 => gear11.trigger
net m12 GB-2speed.0.message.12 => gear12.trigger
net m13 GB-2speed.0.message.13 => gear13.trigger
05 Sep 2018 14:49 - 05 Sep 2018 14:50 #117111
halrun
loadrt GB_2speed
show pin
exit
It's probably message.01
loadrt GB_2speed
show pin
exit
Last edit: 05 Sep 2018 14:50 by andypugh.
05 Sep 2018 14:55 - 05 Sep 2018 14:57 #117112
by tecno
Message 00 ?
bengt@CombiMll ~ $ halrun
halcmd: loadrt GB_2speed
Note: Using POSIX realtime
halcmd: show pin
Component Pins:
Owner Type Dir Value Name
6 bit IN FALSE GB-2speed.0.gear-A
6 bit IN FALSE GB-2speed.0.gear-B
6 bit IN FALSE GB-2speed.0.gear-C
6 bit IN FALSE GB-2speed.0.gear-D
6 bit IN FALSE GB-2speed.0.gear-E
6 bit IN FALSE GB-2speed.0.gear-high
6 u32 OUT 0x00000000 GB-2speed.0.gear-required
6 bit OUT FALSE GB-2speed.0.message-00
6 bit OUT FALSE GB-2speed.0.message-01
6 bit OUT FALSE GB-2speed.0.message-02
6 bit OUT FALSE GB-2speed.0.message-03
6 bit OUT FALSE GB-2speed.0.message-04
6 bit OUT FALSE GB-2speed.0.message-05
6 bit OUT FALSE GB-2speed.0.message-06
6 bit OUT FALSE GB-2speed.0.message-07
6 bit OUT FALSE GB-2speed.0.message-08
6 bit OUT FALSE GB-2speed.0.message-09
6 bit OUT FALSE GB-2speed.0.message-10
6 bit OUT FALSE GB-2speed.0.message-11
6 bit OUT FALSE GB-2speed.0.message-12
6 bit OUT FALSE GB-2speed.0.message-13
6 bit IN FALSE GB-2speed.0.motor-high
6 float OUT 0 GB-2speed.0.motor-speed-out
6 bit IN FALSE GB-2speed.0.spindle-enable-in
6 bit OUT FALSE GB-2speed.0.spindle-enable-out
6 float IN 0 GB-2speed.0.spindle-speed-in
6 s32 OUT 0 GB-2speed.0.time
halcmd: exit
Message 00 ?
Last edit: 05 Sep 2018 14:57 by tecno. Reason: added text
05 Sep 2018 15:01 - 05 Sep 2018 15:02 #117114
by tecno
./GB_2speed.hal:170: Pin 'GB-2speed.0.message.01' does not exist
Do we need to setp something?
Last edit: 05 Sep 2018 15:02 by tecno.
- Thank you received: 1370
05 Sep 2018 16:26 #117116
Replied by Todd Zuercher on topic Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
it is "GB-2speed.0.message-01" not "GB-2speed.0.message.01"
See the difference? (look at the character before the 01)
05 Sep 2018 16:42 #117117
by tecno
Thanks Todd!
Will change now test soon.
Time to create page: 0.215 seconds
