TTL (PWM) Laser head and Mesa 7i76
03 Dec 2021 10:43 #228272
by RoberCNC
Replied by RoberCNC on topic TTL (PWM) Laser head and Mesa 7i76
Hi PCW, the wiring from the 5i25 P3 to DB25 conector of the BB is going to be 1 to 1? I mean pin1 from the P3 to pin1 of the DB25, pin2 to pin2, etc...
Thx very much.
Thx very much.
03 Dec 2021 15:11 #228289
Replied by PCW on topic TTL (PWM) Laser head and Mesa 7i76
Yes, you normally use a parallel printer cable for this
(if you use the HDR P2 you need a flat cable adapter from HDR26 to DB25)
03 Dec 2021 15:25 #228292
by RoberCNC
Sorry, the P2 wanted to say, I got confused, P3 (the DB25) I have it busy with the 7i76.
I have asked if the pins are the same to prepare the wire.
03 Dec 2021 15:43 #228294
On P2, HDR Pin 1 connects to DB25 Pin 1, but the other pins are
not in order because of the way DB25 and HDR26 pins are numbered.
You don't need a special cable however just a flat cable with IDC
connectors (one HDR26 , one DB25) on each end.
(Mesa can supply these)
The following user(s) said Thank You: RoberCNC
03 Dec 2021 15:53 #228297
by RoberCNC
Ok, I'll wait to do it then with the pins you tell me based on the custom firmware.
29 Jan 2022 11:02 - 29 Jan 2022 11:03 #233424
by RoberCNC
Hi PCW, is there news of the custom firmware?
Last edit: 29 Jan 2022 11:03 by RoberCNC.
29 Jan 2022 20:24 #233480
Here is a 5i25 config with PWM on P2 (it also adds 2 more step/dir outputs)
29 Jan 2022 21:34 #233488
by RoberCNC
Very grateful PCW!!!
I understand that the pinout of the Chinese BB is like the one it has.
I see that in the zip comes a .vhd file, what is it for?
The .bit I imagine is to flash the 5i25 again like I did when I bought it.
Thank you very much, really, how much I want to try it
06 Feb 2022 18:24 #234140
by RoberCNC
Hi PCW.
Just flashed the firmware and verified, it seems to be everything ok.
Now I have some doubts, the first of all I run the Pncconf Wizard and I don´t know what I must to choose on the Mesa Card 0 step at Board Name selection tab (5i25, 5i25-Internal Data, etc...) neither at firmware selector, the 7i76_pwmd doesn´t appears as such.
In the other hand I supposed that with this new firmware I have to remap and reconfig all the pinouts I have, isn´t it?
Thank you very much as allways.
Rober
Rober
06 Feb 2022 18:41 - 06 Feb 2022 18:44 #234146
pncconf is not going to help at this point.
I would use your existing 7I76 configuration (if you have one)
as none of the 7I76 connections have changed, only a added PWM
generator and a couple of step generators have been added to P2
so the only changes needed to your existing hal file are adding
the laser PWM support.
Last edit: 06 Feb 2022 18:44 by PCW.
Time to create page: 0.172 seconds
