TTL (PWM) Laser head and Mesa 7i76
06 Feb 2022 18:54 #234149
by RoberCNC
Replied by RoberCNC on topic TTL (PWM) Laser head and Mesa 7i76
Hummmm I don´t know if I would be able to handle this, yes I have operating configuration, I had rather, now it doesn´t run
How can I map or know the chinese BB pins and the BB itselfs denomination?
It smells as a new challenge and learning for me.
06 Feb 2022 20:12 - 06 Feb 2022 20:13 #234167
Replied by PCW on topic TTL (PWM) Laser head and Mesa 7i76
The firmware did not change any 7I76 connections
so your original hal/ini files should work
The PWM output is on DB25 pin 8 (mesaflash should show this)
Last edit: 06 Feb 2022 20:13 by PCW.
06 Feb 2022 21:47 #234178
by RoberCNC
Well now I am unable to run the configuration that was operational, I launch the application and I get the error screen with a bunch of lines that pin do not exist.
If the firmware doesn't change anything (I thought so too) what could be the cause?
06 Feb 2022 21:57 #234181
What pins are missing and what does:
mesaflash --device 5i25 --readhmid
report?
report?
06 Feb 2022 22:29 #234185
by RoberCNC
Until Thursday I will not be in the place of the machine, which I remember right now it gave me an error on line 39 of the .hal (the first one that appears in the configuration) that corresponds to a limit switch, in the previous warnings more lines.
As soon as I get back I'll check what you say and copy the report first before doing anything else.
11 Feb 2022 10:54 - 11 Feb 2022 10:55 #234558
by RoberCNC
Hi PCW.
Here you have both files we talked about.
Greetings.
Greetings.
Last edit: 11 Feb 2022 10:55 by RoberCNC.
- Thank you received: 5934
11 Feb 2022 21:19 #234608
Replied by tommylight on topic TTL (PWM) Laser head and Mesa 7i76
7i76 has no field power.
The following user(s) said Thank You: RoberCNC
11 Feb 2022 21:28 #234610
by RoberCNC
How can it be possible if I haven't touched anything?
I have simply flashed the new firmware. I'll check it out as soon as possible though. Thank you Tommy.
11 Feb 2022 21:57 #234614
Does the orange connector on the 7i76 have 8V to 28V power going to it?
How is the field power jumper set up?
11 Feb 2022 22:09 #234616
by RoberCNC
I have not touched anything Tommy and it was operational and after writing the new firmware I get the report messages.
However, as soon as I have a moment I will look at it and check what you tell me.
