Gscreen - a GTK / Glade / Python based screen
19 Dec 2018 23:31 - 19 Dec 2018 23:32 #122619
Replied by cmorley on topic Gscreen - a GTK / Glade / Python based screen
initialize_widgets() is where to put initialization code.
status,command and error can be accessed by initializing an instance of them in the __INIT__() function with:
self.command = linuxcnc.command()
self.status = linuxcnc.stat()
self.error = linuxcnc.error_channel()
It's probably available through some other code but that is surely the easiest to work with.
In some cases using GSTAT is a better way to go.
GSTAT monitors some key status and will tell you when they change.
linuxcnc.org/docs/devel/html/gui/GStat.html
Chris M
Chris M
Last edit: 19 Dec 2018 23:32 by cmorley.
- Ivan_The_Red
20 Jan 2019 17:40 #124483
by Ivan_The_Red
Replied by Ivan_The_Red on topic Gscreen - a GTK / Glade / Python based screen
Is Gscreen being phased out ? If it is ,what avenues are there to upgrade or convert an existing Gscreen user interface.
21 Jan 2019 02:24 #124503
There is no immediate plan to phase out Gscreen.
I just gets harder to get the editor to work on newer distributions to modify it.
I heard rumors of python2 support coming to an end in the future but i bet that will still take awhile.
I hope in time to update Gscreen and Gladevcp for gtk3 and python3 but that would be in long time from now (if ever)
QTvcp is the the next in-tree project for machine control in linuxcnc.
Chris M
Chris M
21 Jan 2019 02:27 #124505
I should mention there is a separate PyQtVCP project too.
Chris M
Chris M
- Ivan_The_Red
21 Jan 2019 13:55 #124536
by Ivan_The_Red
Thanks Chris,
Can I open my current Gscreen glade file using the newer QTvcp software and make changes to it or would I need to start all over again?
21 Jan 2019 22:11 #124571
Unfortunately no. QTvcp is not compatible.
Chris M
Chris M
