Gscreen - a GTK / Glade / Python based screen
19 Feb 2012 00:28 - 19 Feb 2012 00:38 #17806
Gscreen - a GTK / Glade / Python based screen was created by cmorley
Last edit: 19 Feb 2012 00:38 by cmorley.
19 Feb 2012 00:35 #17807
Replied by cmorley on topic Re:Gscreen - a GTK / Glade / Python based screen
19 Feb 2012 01:06 #17811
gscreen patch to go against current as of now master.
adds fullscreen (not maximize - all of it!) capability
adds an embedded terminal for call debugging programs.
adds an option to use aux coolant instead of mist or flood
this was requested by my only tester cncbasher, it requires one to connect HAL to gscreens coolant pins instead of linxcnc's
fixed save and save-as for gcode edits.
probably some other stuff
19 Feb 2012 01:11 #17812
Cncbasher had a problem when first opening gscreen because of the preference file.
so here is a copy of a preference file if that happes.
name it '.gscreen_prefences' (without quotes, note the period) and put it in your home file.
The following user(s) said Thank You: Diederik
19 Feb 2012 01:16 - 19 Feb 2012 01:16 #17813
here is the patch as a compressed file - alot easier
Last edit: 19 Feb 2012 01:16 by cmorley.
19 Feb 2012 11:53 - 19 Feb 2012 11:55 #17825
by cncbasher
Replied by cncbasher on topic Re:Gscreen - a GTK / Glade / Python based screen
just about to take the step now of configuring without axis , for the first time , so jumping without a safety net ! ( only figuratively thank god )
but all seems to fit in well , touch screen is working fine , no difficultys selecting etc .
now a machine on togglebutton , with colour change red / green so you can see status perhaps
needs to be i think on the right side under the estop , or perhaps top left next to status .
in a similar style to the estop and led i think would suit better
Last edit: 19 Feb 2012 11:55 by cncbasher.
19 Feb 2012 13:43 #17828
by BigJohnT
Replied by BigJohnT on topic Re:Gscreen - a GTK / Glade / Python based screen
I can't wait to get out to the shop and try this... way to go Chris!
- Dan Falck
- Visitor
19 Feb 2012 17:43 #17834
by Dan Falck
Replied by Dan Falck on topic Re:Gscreen - a GTK / Glade / Python based screen
Looks very nice! Where is it located? (git repo?)
19 Feb 2012 18:44 #17836
by cncbasher
look a few messages back Dan , and install against emc2-dev git repro , then rebuild
shout if your stuck
Dave
shout if your stuck
Dave
19 Feb 2012 19:18 - 19 Feb 2012 19:26 #17837
it's in git repo of my private computer.
If it proves worthwhile and functional I will incorporate in linuxcnc.
right now still experimenting, though it will run a standard machine.
Chris M
I warn you - its still being developed and tested please test in a simulated config.
there are a couple hidden features that could move the machine unexpectedly.
Chris M
Last edit: 19 Feb 2012 19:26 by cmorley.
Time to create page: 0.263 seconds
