Gscreen - a GTK / Glade / Python based screen
21 Feb 2012 09:28 - 21 Feb 2012 09:37 #17902 by cmorley
If you wish to have gscreen as well as the original screen then instead of changing the DISPLAY = setting
under the [HAL] heading
add:
HALCMD = loadusr gscreen -ini gscreen.ini
changing the ini filename as appropriate.
Last edit: 21 Feb 2012 09:37 by cmorley. Reason: typo
21 Feb 2012 09:33 #17903 by cncbasher
thanks for that Chris
23 Feb 2012 21:51 #17984 by robh
this look svery intresting nice work keep it up
ill try and give it a test drive when i have afree afternoon
rob
24 Feb 2012 23:49 #18053 by robh
just got to try this out
very nice i must say
would it be possible to have a colour system on the program edit screen. ie , rapid txt lines in red, feeds in green etc , as my full editor on windows we use alot has this sort of thing and it becomes very quick eye reff after awhile,
would it be possible to add a offset table for work coordinates to view and edit, g54,g55 etc
25 Feb 2012 01:46 #18057 by karlkec
cmorley wrote:
Michael is hosting gscreen on his git repo.
git.mah.priv.at/gitweb/emc2-dev.git
I tried gscreen using the zipped patch above and it looks good. So now it's my turn to ask a dumb question.
I want to get the latest version so I tried to clone it into a new directory with
git clone git.mah.priv.at/gitweb/emc2-dev.git emc2-dev
but git complained:
remote HEAD refers to nonexistent ref, unable to checkout
Is there a way I can do this?
Karl
25 Feb 2012 02:10 #18058 by robh
u need to do this from master git
so dont know if u did a new pull or not but below will not hert
in the Git tree to wish to apply it to
git reset --hard remotes/origin/master
git pull origin master
git merge git.mah.priv.at/gitweb/emc2-dev.git gscreen_master
or if it fails try
git pull git.mah.priv.at/gitweb/emc2-dev.git gscreen_master
then do config make etc
rob
25 Feb 2012 03:20 #18064 by cmorley
it is possible to see the current work offsets. double click the plot area and set show offsets in the preference page.
yes a tool offsets editor is on the to do list.
chamging the colors of the gcode text should be possible but not in Gscreen. I'll look into how to do that.
Chris m
25 Feb 2012 03:38 #18066 by karlkec
Rob,
Thanks for the reply. Still having problems.
That worked fine.
That didn't work:
fatal: 'git.mah.priv.at/gitweb/emc2-dev.git' does not point to a commit
That also didn't work:
fatal: Couldn't find remote ref gscreen_master
I'm not sure if it's right, but I inserted http:// to make the git URL. Otherwise it wasn't recognized as a remote reference. I also tried git:// but I don't have access.
Karl
25 Feb 2012 09:37 - 25 Feb 2012 09:39 #18072 by cncbasher
git pull git://git.mah.priv.at/emc2-dev.git gscreen_master
should get you there
Last edit: 25 Feb 2012 09:39 by cncbasher.
25 Feb 2012 14:53 #18081 by karlkec
That did it. Thank you very much.
Karl
Time to create page: 0.200 seconds
