Gscreen - a GTK / Glade / Python based screen
26 Jul 2013 11:14 #37053
Replied by cmorley on topic Gscreen - a GTK / Glade / Python based screen
Can you send me the original screwed up tooltable file?
Chris M
Chris M
26 Jul 2013 21:02 #37069
by tjamscad
Replied by tjamscad on topic Gscreen - a GTK / Glade / Python based screen
Chris,
This is a quick tool seting link from a fanuc control. The button might not be the same but the princple is for almost macines.
www.wisc-online.com/objects/ViewObject.aspx?ID=MTL17302
27 Jul 2013 07:51 #37080
I think this is probably nothing to do with Gscreen. I think I have heard of this before, it is something to do with a blank line either present where it shouldn't be or absent where it should be in the tool table file.
(I really need to get back to the task of replacing this bug with newer ones)
Replied by andypugh on topic Gscreen - a GTK / Glade / Python based screen
27 Jul 2013 09:09 - 27 Jul 2013 09:09 #37085
by LAIR82
Are you possibly refering to the semicolon on the first line? I see this mentioned in the Tool Table Wiki. What is the purpose of this and if it was missing would this possibly give me this fault?
Rick
Replied by LAIR82 on topic Gscreen - a GTK / Glade / Python based screen
Rick
Last edit: 27 Jul 2013 09:09 by LAIR82.
30 Jul 2013 19:56 #37262
by LAIR82
Here is a copy of the tool file that it would not read, I don't see anything wrong with it though.
We are trying to see if there is a sequence of events that is causing this, or how we are entering our data in to the tooledit page, example, does 0.0010 make any difference than .0010. Again, the only way to get " Requested tool XX not found in tool table" to go away is to delete the tool, and then re-add it, using the delete and add buttons in the tooledit widget.
If we find anything I will report back ASAP.
Rick
Rick
31 Jul 2013 00:46 #37276
by tjamscad
Chris,
Did you get my theme working on your system? I was just looking through some old posts and saw one about the sliders widths.
01 Aug 2013 09:10 #37319
I did yes thanks.
Chris
Chris
26 Aug 2013 19:10 #38107
by LAIR82
Hello Guys,
I am moving this conversation to www.linuxcnc.org/index.php/english/forum...87-tool-offset-patch, I am pretty confident that it is something with the way this patch is handled and not gscreen.
Rick
Rick
Hello Guys,
Rick
04 Oct 2013 05:03 #39521
by newbynobi
Replied by newbynobi on topic Gscreen - a GTK / Glade / Python based screen
Halo Chris,
Translating gscreen I noticed some messages like 'can't switch spindle on manuell while in AUTO mode'
Why that? That has been sorted out and is allowed from linuxcnc.
So I beleave that is a relict from the past.
I do allow spindle and coolant switching at any mode in gmoccapy.
Norbert
Norbert
04 Oct 2013 09:28 #39523
You are right I have not updated that option yet.
Chris M
Chris M
Time to create page: 0.277 seconds
