Gscreen - a GTK / Glade / Python based screen
18 Jul 2013 19:37 #36771
by tjamscad
That might be better. How does that work?
Replied by tjamscad on topic Gscreen - a GTK / Glade / Python based screen
This is why the operators dont like the picture show (gremlen). This is just a small 3 axis part and it already looks like spegitti.
It's possible to turn off different plot options, such as rapid moves etc - might make it easier to see.
probably could get it down to feed moves and current tool position .
Chris M
19 Jul 2013 22:06 #36806
by tjamscad
Chris,
I was just working with one of the operators and he asked me if gscreen (LinuxCNC) would run graphics. I thought he was talking about the gremlin display but he showed me on a couple of machines Fadal and Haas. This is an option to run the program with out machine motion. It is only preformed on the display (monitor) and it looks like it would work if it was the same as the gremlin display that runs when the machine is running only with no motion. Is this possible?
20 Jul 2013 06:48 #36814
Replied by cmorley on topic Gscreen - a GTK / Glade / Python based screen
yes Okuma called this dry-run.
Gremlin wasn't made to do this, but the principal should work. It actually does this behind the scenes and quickly - that's how it plots the program.
How much work It would be to get gremlin to do this I don't know.
It would be an interesting project. Not one I'm prepared to try right now.
Chris M
Chris M
20 Jul 2013 15:59 #36819
by newbynobi
Replied by newbynobi on topic Gscreen - a GTK / Glade / Python based screen
Why not make two configuration files, one as real machine and one as simulate machine?
So switching between both will fit your needs.
Norbert
Norbert
21 Jul 2013 02:28 #36842
Because operators on the floor should not be expected to start and stop linuxcnc.
In fact in most cases they should not be able to.
Also if they did they would have to home the machine and probably touch off again, which is not very productive just to verify an edited program.
Chris M
Chris M
21 Jul 2013 02:42 #36843
by newbynobi
OK, in the tool shop the opperator should not touch the system, I have on my machine two computers with a network connection, so I can run the programm on one in simulation and on the other live with the machine.
The simulate computer can operate 2 mills and one lathe.
Norbert
Norbert
21 Jul 2013 03:08 #36845
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Gscreen - a GTK / Glade / Python based screen
I hope this is the right place for me to place this. This is very strange indeed I know but my debug terminal does not read the "r" key. I tested all the other keys but the "r' is not working. "R" works. Is this possible?
Regards
Marius
www.bluearccnc.com
21 Jul 2013 04:17 #36846
This is possible. One of my low power machines does this (and not all the time).
I have no idea why or a cure.
Chris M
Chris M
21 Jul 2013 16:22 #36852
pushed a new layout of industrial -now the onboard keyboard can be available anytime.
new calculator launch button.
Shannon: to answer your question about gremlin options. It requires a little python code to turn the options on and off.
I am a little bogged down right now to work on it.
On a simulator, try Gmoccapy. Norbert has exposed some of the options, and has buttons to click them on and off.
i just can't remember what options he has controls for....
Chris M
Chris M
21 Jul 2013 17:15 #36856
by newbynobi
gmoccapy offers the following gremlin function as buttons:
- Perspective view
- X View
- Y View
- Y2 View (Only in lathe mode)
- Z View
- Zoom in
- Zoom out
- dimensions on or off
- Tool Path on / off
- clear tool path
What is missing? I may be able to find space to add more button.
Norbert
- Perspective view
- X View
- Y View
- Z View
- Zoom in
- Zoom out
- clear tool path
Norbert
Time to create page: 0.404 seconds
