Lathe Macros
- JackBerkhout
28 Dec 2017 15:32 #103796
by JackBerkhout
Replied by JackBerkhout on topic Lathe Macros
Hi Andy,
that looks nice. I'm not sure how it works.
Also, I noticed do not have the 'Cycles' tab with all the tabs below that.
Do I need to download and install software for that?
04 Jan 2018 15:49 #104023
Replied by andypugh on topic Lathe Macros
You need to create the "Cycles" tab with an edit to the INI file.
The following user(s) said Thank You: JackBerkhout
- AppleAssassin
22 Jan 2018 05:04 #104829
by AppleAssassin
Replied by AppleAssassin on topic Lathe Macros
Anyone else having the problem where it won't run and says "unable to open file <turning>" for example. It's the same for any operation like "unable to open file <boring>" etc.
22 Jan 2018 07:55 #104833
Where have you put the files in question? You might need to add that location to the SUBROUTINE_PATH
- AppleAssassin
22 Jan 2018 14:31 #104843
by AppleAssassin
I put them in the configs folder for my profile then changed the INI file with the EMBED_TAB_NAME and EMBED_TAB_COMMAND lines. Now when I click the little play button on the Cycles interface nothing happens but the text on the window border changes to (no file)
22 Jan 2018 15:15 #104848
You probably need to add :./ to the SUBROUTINE_PATH.
(ie, the folder containing the INI)
The lathemacro.ini has
SUBROUTINE_PATH = ../../../nc_files/gladevcp_lib:./
16 Feb 2018 08:54 #106006
by Coockie
Replied by Coockie on topic Lathe Macros
Hello! Im installed Linux cnc on my old computer, all ok, next step i will install your macros, im install it, but background picture does not displayed... what i doing wrong?
25 Feb 2018 20:48 #106515
It may be that your installation does not have the required SVG file viewer.
If you start LinuxCNC from the command line it is possible that you might get a message saying what the problem is.
26 Feb 2018 19:00 #106547
by Coockie
Okay, greet thank you! Im try repair it) Sory for my bad english
06 Apr 2018 11:17 #108488
by tecno
Replied by tecno on topic Lathe Macros
Can somebody please point out where I can find the axis-lathe.ngc with all necessary sub routines for Lathe Macro?
Time to create page: 0.266 seconds
