Lathe Macros
04 Jun 2016 12:09 #75483
by RotarySMP
Replied by RotarySMP on topic Lathe Macros
Thanks Andy,
Guess that rules it out for the Boley, which has manual belt changes and a two speed motor.
I also have little 7x Lathe I converted years ago. It has a VFD on it, but I never got around to replacing the speed pot with the interface widget to control it from LinuxCNC. Guess I need to set that machine back up and use it to try out your macros.
In the mean time I guess I'll set up NGCGUI or features.
Mark
Mark
04 Jun 2016 12:24 #75484
Each operation is a simple bit of G-code. You just need to edit the G-codes to suit your machine.
Do you have a spindle encoder?
Replied by andypugh on topic Lathe Macros
Thanks Andy,
04 Jun 2016 23:21 - 04 Jun 2016 23:22 #75512
by BigJohnT
Replied by BigJohnT on topic Lathe Macros
Last edit: 04 Jun 2016 23:22 by BigJohnT.
06 Jun 2016 07:11 #75542
by RotarySMP
Thanks Andy and JT,
I have a spindle encoder already installed and working. I was just dry running the controller away from the machine, getting to know it.
Mark
Mark
- oscarconde6
08 Aug 2016 22:52 #78505
by oscarconde6
Replied by oscarconde6 on topic Lathe Macros
Hello everyone, I am new to the forum, I am Spanish and I have to translate to speak here, to thank the people who do these jobs are very good.
I read a lot of information these last weeks to motorize my around with linux cnc and it seems that I managed to move with a TB6560 and two step-step motors card, yet not I have encoder for the spindle but I'm starting. I linuxcc 2.7.0 and I installed lathemacros3 as I read in the download but when pressed the play and accept the tool lathe makes the first political movement and then stays in play but not continuous, took several days and do not get a solution my level of programming is very low, someone could help me, thank you very much, have if you understand me with this translation,
09 Aug 2016 00:53 #78509
If you don't have a spindle encoder then you will need to edit the G-code routines to not use Constant Surface Speed or Feed-per-revolution G-codes. And you will not be able to thread.
But that's just G-code, and you need to learn that to do CNC
09 Aug 2016 20:14 - 09 Aug 2016 20:14 #78541
by Rick G
Replied by Rick G on topic Lathe Macros
Might want to look here...
forum.linuxcnc.org/forum/lathe-subroutines-library
Some of the subs such as
forum.linuxcnc.org/forum/lathe-subroutin...26977-odtaper-lathe3
Do not use constant surface speed so may run for you and serve as a starting point.
Rick G
Rick G
Last edit: 09 Aug 2016 20:14 by Rick G.
- oscarconde6
09 Aug 2016 22:50 #78548
by oscarconde6
thanks for the quick reply, do what you tell me I will try to learn a little more and forums have mirare I can do. I'm one. little lost with the codes g. Thank you
10 Aug 2016 08:56 - 10 Aug 2016 08:57 #78564
The lathe macros include a set of G-code routines, for example turning.ngc looks like this:
The important parts are the lines
You would need to change those (in each of the routines) to
linuxcnc.org/docs/2.7/html/gcode/g-code.html#gcode:g96-g97linuxcnc.org/docs/2.7/html/gcode/g-code.html#gcode:g93-g94-g95
Then the boxes in the macro tabs are feed-per-min and rpm.
You will find that the surface-speed adjustment does not allow big enough numbers to be a RPM input. So you will need to modify the "Adjustment" properties of the UI. You could do that in the Glade editor, but it it probably easier to do it with a text editor and alter the numbers directly. For example, for turning RPM look forand change the limits and step size. Then work through the other adjustments making them suit too. Unfortunately I have just noticed that I got lazy at giving the adjustments meaningful names. This means you need to look through the code to find that the "face.sf" control for the facing routine is constrained by "adjustment10"
;Turning
O<turning> sub
G8 ; Radius mode (easier maths)
G18 ; XZ Plane
G21 ; Metric Units
G90 ; Absolute Distance
G91.1 ; but not for arcs
M6 T#8 G43
#1 = [#1 / 2] ; because of radius mode
#14 = [#<_x>] (starting X)
#13 = #<_z> (starting Z)
#20 = [#6 * SIN[#7]]
#21 = [#6 * COS[#7]]
#22 = [#6 / COS[#7]]
#23 = [#5 + #6 - #20]
#24 = [[#13 - #23] * TAN[#7]]
G96 D1500 S#2 ; Constant Surface Speed Mode
m3 ;Start Spindle
g95 F#4 ; Feed-Per-Rev Mode
g4p1 ; Wait to reach speed
/ (debug, Turning finish rad #1 start rad #14 start length #13 finish length #5)
/ m1
O100 WHILE [#14 GT [#1 + #3 / 2]]
g0 X #14
#14=[#14-#3 / 2]
G1 X #14
G1 Z #23 X[#14 + #24]
O101 IF [#6 GT 0]
G2 Z#5 X[#14 + #24 + #21] I#21 K#20
G1 X[#14 + #24 + #21 + #3/2]
O101 ELSE
G1 X[#14 + #24 + [#3 * .6]]
O101 ENDIF
O104 IF [#7 LT 0]
G0 X#14
O104 ENDIF
G0 Z[#13]
O100 ENDWHILE
G0 x#1
G1 Z #23 X[#1 + #24]
O102 IF [#6 GT 0]
G2 Z#5 X[#1 + #24 + #21] I#21 K#20
G1 X[#1 + #24 + #21 + #3]
O102 ELSE
G1 X[#1 + #24 + #3]
O102 ENDIF
O106 IF [#7 LT 0]
G0 X#14
O106 ENDIF
G0 Z #13
G0 X #1 ; For touch-off
M5
G7
O<turning> endsub
M2
m3 ;Start Spindle
G97 S#2 ; Constant RPM Mode
m3 ;Start Spindle
g94 F#4 ; Feed-Per-Minute
<object class="GtkAdjustment" id="TurnSFAdj">
Last edit: 10 Aug 2016 08:57 by andypugh.
- oscarconde6
10 Aug 2016 15:42 #78578
by oscarconde6
many andy thanks, I followed your instructions and I've got a routine run but very slow, if I change in routine f # 4 and put f50 for example routine runs at that speed, I could not set the variable # 4 to use the tab macro, I achieved that value can be modified until 1000 but when I run the routine does not raise the speed I have to change a few lines but which are not put file photo that allegedly have to modify for use eyelash correct speed. Thank you
from what I understand is that I have to change some lines of these images I think the problem is that I have to translate the issues and not translated into 100% and only understand a few things. have if I'm on track. thanks for the patience
Time to create page: 0.229 seconds
