My custom designed GUI
28 Nov 2013 12:09 #41196
by pietvr
My custom designed GUI was created by pietvr
Hi
This was done with a lot of help from John's python tutorial. Thanks John
A lot of thanks to Andy as well for help with HAL issues I had.
The machines I build are all going out with LinuxCNC and my custom GUI unless the customer demands WinXP with Mach3.
Regards
Piet
Regards
Piet
28 Nov 2013 16:04 #41199
by emcPT
Replied by emcPT on topic My custom designed GUI
This is very nice.
Can you share the files to produce this? I am interested in creating a screen for lathes.
The following user(s) said Thank You: pietvr
28 Nov 2013 19:53 #41208
by BigJohnT
Replied by BigJohnT on topic My custom designed GUI
Very nice and I'm glad my tutorials could help.
JT
JT
The following user(s) said Thank You: Catch22
29 Nov 2013 06:22 - 29 Nov 2013 06:28 #41214
by DaOne
Replied by DaOne on topic My custom designed GUI
Last edit: 29 Nov 2013 06:28 by DaOne.
29 Nov 2013 06:24 #41215
by newbynobi
Replied by newbynobi on topic My custom designed GUI
Halo Piet,
I like your design, did you make all the widgets yourself, or is that just a custom theme?
Where can I see the machines you make?
Norbert
Norbert
29 Nov 2013 07:00 #41216
by pietvr
Replied by pietvr on topic My custom designed GUI
@ DaOne - Yes that is the tutorial
@ Norbet, Craftsman CNC The screens were done on PagePlus, desktop publishing software, which was then imported into Glade and the widgets laid out on top of the imported images
@emcPT it is a whole project, not only a few files of code
29 Nov 2013 20:39 #41221
by BigJohnT
How did you force the glade widgets to be the correct shape and size?
JT
JT
30 Nov 2013 00:41 #41223
by newbynobi
Halo Piet,
where can I find the source code?
Norbert
Norbert
30 Nov 2013 03:38 #41227
by pietvr
@ JT - I wrote a scale function so the widgets scales to any screen size. I used transparent event boxes instead of buttons. I had to tweak some of the GladeVCP code so the widgets such as the LED's will have scaled sizes.
@ Norbert and emcPT - I will tweak and clean up my code a bit, as it was done specifically for my machines. I also had to change some of the GladeVCP objects to suite my needs and they no longer work correctly in Axis, such as gremlin. Once done I will post the project.
30 Nov 2013 07:08 #41232
by BigJohnT
Is the scale function part of the python file? I'd love to see it...
JT
JT
Time to create page: 0.119 seconds
