My custom designed GUI
31 May 2016 10:48 #75275
by cncbasher
Replied by cncbasher on topic My custom designed GUI
make sure the file have execuitable rights in properties i.e can run as a program
07 Jun 2016 13:13 #75638
by aer73
Replied by aer73 on topic My custom designed GUI
Many thanks Cncbasher.
I try that you say but no works.
Regards.
Regards.
07 Jun 2016 14:25 #75640
by cncbasher
the error is
File "/home/sarah/linuxcnc/configs/craftsmancnc/bin/craftsman_toolchange", line 10, in <module>
import globals
ImportError: No module named globals
./craftsmancnc.hal:146: waitpid failed craftsman_toolchange craftsman_toolchange
./craftsmancnc.hal:146: craftsman_toolchange exited without becoming ready
i'll take a look later today
import globals
The following user(s) said Thank You: aer73
07 Jun 2016 15:02 #75642
Replied by andypugh on topic My custom designed GUI
My first guess would be that the filename and the component name don't match.
A .comp file needs to have a component name in HAL that matches the file name.
07 Jun 2016 16:39 #75647
by aer73
Many thanks to both for take your time in help me.
@Cncbasher, that error is similar to mine.
@AndyPugh, can you be more explicit about filename and the component name don't match?
Don´t understand too A .comp file needs to have a component name in HAL that matches the file name.
Many thanks to both again for your help.
Kindly regards.
Kindly regards.
07 Jun 2016 17:24 #75649
I am assuming that craftsman_toolchange is a .comp file, that might not be the case.
What is it?
Don´t understand too A .comp file needs to have a component name in HAL that matches the file name..
What is it?
07 Jun 2016 18:16 #75652
by aer73
Andypugh Wrote:
I attacht it.
Many thanks.
Regards.
I think maybe you have reason about comp file, beecause is a .dat file.I am assuming that craftsman_toolchange is a .comp file, that might not be the case.
I attacht it.
Many thanks.
Regards.
07 Jun 2016 18:33 - 07 Jun 2016 18:39 #75654
The file you attached is a single byte file containing only the character "0".
Is that really your craftsman_toolchanger file?
I found the file in the earlier zip file. It's a python file, an alternative to hal_manualtoolchange.
It seems to do the right things:
h = hal.component("craftsman_toolchange")
h.ready()
Last edit: 07 Jun 2016 18:39 by andypugh.
07 Jun 2016 18:49 #75655
by aer73
You have reason i send a wrong file, sorry me.
But i don´t what you wanna say with the rest of your words.
Sorry again.
Many thanks for your help.
Kindly regards.
Sorry again.
Kindly regards.
08 Jun 2016 06:58 - 08 Jun 2016 07:03 #75672
by pietvr
Replied by pietvr on topic My custom designed GUI
Hi
You will need to edit the following line in the 3 files in the bin folder (craftsmancnc, craftsman_toolchange & vfd_spindle)
sys.path.append('/home/craftsman/linuxcnc/configs/craftsmancnc/')
should be changed to your local configuration:
sys.path.append('/home/sarah/linuxcnc/configs/craftsmancnc/')
In the crafstmancnc file there is another line to be changed:
xmlname = os.path.join('/home/craftsman/linuxcnc/configs/craftsmancnc/',"craftsmancnc.glade")
to:
xmlname = os.path.join(''/home/sarah/linuxcnc/configs/craftsmancnc/'',"craftsmancnc.glade")
These files should also be set in their properties to "Execute"
The file vfd_controller in your /home/sarah/linuxcnc/configs/craftsmancnc/ folder also has the line:
needs to change to:
Note: the /sarah/ part should be changed to your local configuration name.
The file you have attached, toolchange.dat, only keeps track of what tool is currently loaded when running a gcode file.
Hope it helps
Piet
to:
needs to change to:
Hope it helps
Piet
Last edit: 08 Jun 2016 07:03 by pietvr.
Time to create page: 0.172 seconds
